19richie66 17,765 #26 Posted November 7, 2022 1 hour ago, The Freightliner Guy said: He’s saying can you pull the small gear so in contact the big gear well that’s what I think he’s trying to say Yes. Couldn’t think of a better way to describe it at the time. Just was wondering if your gear was stuck or could you move it out to make contact with the flywheel. 1 Share this post Link to post Share on other sites
Snoopy11 5,723 #27 Posted November 7, 2022 45 minutes ago, pfrederi said: use jumper cables. Black to Battery NEG and a clean bolt on the engine block. Red to battery positive and touch other end to the starter input terminal. If it engages you have a weak solenoid or more like bad ground somewhere. if it doesn't work load test battery it is bad. So many electrical problems here come back to weak battery or bad ground. Precisely what I would do in this case... Just make sure the battery you test with is good... Don Share this post Link to post Share on other sites
953 nut 63,031 #28 Posted November 7, 2022 On 10/31/2022 at 7:09 PM, 953 nut said: If your battery is good and you have good battery cables 4 hours ago, Kibbie01 said: that solenoid for the ford didnt work. I hooked it up and it didnt even click. when I installed the other one back on, it started working. well, the starter started spinning, but would never engage. not sure what the issue is now? Take you battery to an auto parts store to have it load tested. Remove all battery cables including grounds and clean and inspect all terminals, then tighten the connectors. It is likely that you have a bad connection causing a voltage drop. Here is an explanation of the problems that can be caused by corrosion on electrical connections that was provided by @Save Old Iron The connectors used in this tractor series are in a harsh, corrosive environment caused by vapors from the battery being charged over a few decades.. Vibration causes the connections to loosen - corrosion starts within the metal terminals and a voltage drop develops across the corrosion. If you have a 10 amp current flowing across a 1 ohm resistance (contact corrosion) the electrical formula to calculate power is current squared times resistance so 10 amps x 10amps x 1 ohm resistance = 100 watts !! 100 watts of connector heating is the same as laying a 100 watt soldering iron on the connector Share this post Link to post Share on other sites
Kibbie01 28 #29 Posted November 8, 2022 thanks, I will try that tonight 1 Share this post Link to post Share on other sites
Kibbie01 28 #30 Posted November 28, 2022 I got it to turn over now. starter was fine. my jump box wasnt giving it enough power to make the starter engage. not i have a No Spark issue. I have changed the spark plug and the spark plug wire. I have power to the coil on both sides. my last 14 HP Kohler, I have an issue with the voltage meter connection. could that be causing my no spark issue? 1 Share this post Link to post Share on other sites
953 nut 63,031 #31 Posted November 28, 2022 4 hours ago, Kibbie01 said: t i have a No Spark issue. I have changed the spark plug and the spark plug wire. I have power to the coil on both sides Have you cleaned the contacts on your ignition points? Share this post Link to post Share on other sites
Kibbie01 28 #32 Posted December 1, 2022 where are the ignition points? Is that the small box at the front of the motor? 2 Share this post Link to post Share on other sites
oliver2-44 11,063 #33 Posted December 1, 2022 40 minutes ago, Kibbie01 said: where are the ignition points? Is that the small box at the front of the motor? Yes. Look closely at the point when open to see if the contact s (round buttons) are smooth (but probable oxidized). If they are fairly smooth take a dollar bill or piece of brown paper bag and pull it through them like sand paper to remove the oxidized coating. if they are rough or have a "tip" on them take a ignition file or fine sand paper (a finger nail emery board works if the wife doesn't catch you) and sand of the tip off. 1 Share this post Link to post Share on other sites
Kibbie01 28 #34 Posted December 1, 2022 Thanks. I will try to get that done this weekend. The GT 14 front grill and gas tank has to be removed to I can get to the points. 1 Share this post Link to post Share on other sites
953 nut 63,031 #35 Posted December 1, 2022 8 hours ago, oliver2-44 said: (a finger nail emery board works if the wife doesn't catch you) OH, she will know! Best off to just buy your own finger nail file if you need one, could save your marriage. 1 1 Share this post Link to post Share on other sites
Sailman 1,305 #36 Posted December 1, 2022 I may be mistaken but are we sure the GT 14 has points? I thought it had a different type of ignition system. Can't remember the name but more of an electronic type that didn't use points. I seem to remember folks talking about converting the GT 14 to a points ignition due to the cost and difficulty finding the original type if it goes bad. Maybe some other GT 14 experts here can chime in and confirm. Share this post Link to post Share on other sites
953 nut 63,031 #37 Posted December 2, 2022 When they left the factory fifty or more years ago the GT-14 had a trigger ignition but as you said the parts are hard to come by if they fail. Here is a thread @Aldon did a while back. Share this post Link to post Share on other sites
19richie66 17,765 #38 Posted December 2, 2022 I believe the 69/70 used the breakerless ignition. 71/72 came with points. I could be wrong 👍 1 Share this post Link to post Share on other sites
Kibbie01 28 #39 Posted December 10, 2022 Thanks guys. I cleaned and set the points. Fires up now. I did however take the last bolt off and dropped the grill and the gas tank. Now the gas tank “nozzle” has a crack in it right at the tank. Any suggestions on how to fix that? 1 Share this post Link to post Share on other sites
Kibbie01 28 #42 Posted December 12, 2022 of course i have another issue on my GT 14. My screw for the hydraulics just spins when I try to tighten it. They guy I git it from said he turned the screw so he could push it on the trailer. I have left it that way till after I git is started. now the motor is running, but that screw just keeps spinning. Doe you think it just the screw, or do I now have a running GT 14 that will not go anywhere? 1 Share this post Link to post Share on other sites
pfrederi 19,271 #43 Posted December 12, 2022 There should be a roll pin stuck through end of the valve stem. It should stick farther out one side than the other. Turn valve so the long end faces front. You should be in business. Turn long end towards the rear you can roll the tractor, Have you downloaded the operators manual for the GT14??? Share this post Link to post Share on other sites
Kibbie01 28 #44 Posted December 12, 2022 it just keeps spinning. on my C-141, the stem would stop. I had to tow it when it cut off in the field, so I had to tow it back. the GT 14 stem just spins with no tension. it just feels loose or not threaded. 1 Share this post Link to post Share on other sites
pfrederi 19,271 #45 Posted December 12, 2022 (edited) 1 hour ago, Kibbie01 said: it just keeps spinning. on my C-141, the stem would stop. I had to tow it when it cut off in the field, so I had to tow it back. the GT 14 stem just spins with no tension. it just feels loose or not threaded. Spinning...trhat is the way it should be... it is a port valve. Look at the manual Edited December 12, 2022 by pfrederi Share this post Link to post Share on other sites
Kibbie01 28 #46 Posted December 14, 2022 You know of anyone that has an electric PTO clutch for the deck? I think I am missing a spindle or something as well. Looks like there is a shield that covers the deck belt that is also missing. 1 Share this post Link to post Share on other sites
daveoman1966 3,881 #48 Posted December 14, 2022 I think thyis is the arm you need...PIVOT ARM 6725 I have one, but it was broken and has been BRAZE WELDED. It should work ok. $30 bux for it...shipped. This pic shows the side mule drive from an old Bronco 14... same part # 6725 for the GT-14. Share this post Link to post Share on other sites
Kibbie01 28 #49 Posted December 15, 2022 how can i purchase it? Paypal? 1 Share this post Link to post Share on other sites
Kibbie01 28 #50 Posted December 15, 2022 Do you have a Electric PTO cluch as well? 1 Share this post Link to post Share on other sites
