Goldnboy 1,081 #1 Posted October 24, 2022 Any members use solid bars/straps instead of chain for connecting the rear rockshaft to the clevis hitch. I will be using a rear scoop tote and was thinking these will be necessary Shown are some methods used by other brands. 2 Share this post Link to post Share on other sites
kpinnc 17,297 #2 Posted October 24, 2022 Unless you find a way to make a solid (non-flexible) connection from the belly rockshaft to the rear one, solid lift links won't provide any down pressure. Down pressure on these light tractors is somewhat overrated. At best, you simply break traction at the rear wheels regularly on high spots. On most implements (not sure about the scoop), you're better off adding weight to the implement somehow so far as creating more "bite" back there. 2 Share this post Link to post Share on other sites
Handy Don 16,019 #3 Posted October 25, 2022 3 hours ago, Goldnboy said: Any members use solid bars/straps instead of chain for connecting the rear rockshaft to the clevis hitch. I will be using a rear scoop tote and was thinking these will be necessary Of course, you aren't expecting to get down pressure, right? (Can't push on the cable between the mid- and rear-rockshafts ) The only concerns I would have are: - is there enough clearance under the seat at the rear rockshaft for the link and its fasteners through the full range of motion - does the link put any lateral pressure on the rear rock shaft by pulling it toward one side (a chain or cable clevis pulls in the middle, a single solid link might not) The double link you picture would take a lot of room under the seat (though it would give a lot of length adjustability, if that was important) 1 Share this post Link to post Share on other sites
ebinmaine 77,549 #4 Posted October 25, 2022 4 hours ago, Goldnboy said: Any members use solid bars/straps instead of chain for connecting the rear rockshaft to the clevis hitch. I will be using a rear scoop tote and was thinking these will be necessary Do you have pics of the implement? 1 Share this post Link to post Share on other sites
Goldnboy 1,081 #5 Posted October 25, 2022 (edited) I am thinking about replacing the chain to the rockshaft. I am thinking backing into a pole of mulch with cause the chain to buckle up Edited October 25, 2022 by Goldnboy 2 Share this post Link to post Share on other sites
ebinmaine 77,549 #6 Posted October 25, 2022 Seems to me there should be a cable there. Not a chain? Also thinking said cable would normally go under the seat bracket? 7 hours ago, Goldnboy said: I am thinking backing into a pole of mulch with cause the chain to buckle up I can see your logic there. How's the angle of approach to the rock shaft? Would the solid rod have to be in a bow or arc shape? Share this post Link to post Share on other sites
Handy Don 16,019 #7 Posted October 25, 2022 13 hours ago, Goldnboy said: I am thinking about replacing the chain to the rockshaft. I am thinking backing into a pole of mulch with cause the chain to buckle up The chain is only ONE of TWO flexible links in the rear lift setup. There is a cable running through a tube from the mid-tractor rock shaft to the rear rock shaft. You have a chain from rear rock shaft to implement (some users replace this with a cable) You can replace the chain with a solid link, but the cable will still buckle on compression. 1 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #8 Posted October 25, 2022 @GoldnboyI would like to see how you plan to attach the bucket to the hitch. You could attach an electric actuator to move the hitch up and down . I ran actuator to my clevis hitch so I could mow and use the rear hitch at the same time. It was a bit of a pain but it worked. If I can find the thread I will show what I had to do. Share this post Link to post Share on other sites
Goldnboy 1,081 #9 Posted October 26, 2022 This is a better picture of the scoop 1 Share this post Link to post Share on other sites
Handy Don 16,019 #10 Posted October 27, 2022 15 hours ago, Goldnboy said: This is a better picture of the scoop So it's on a sleeve hitch. How does the dump lock/release? 1 Share this post Link to post Share on other sites
Goldnboy 1,081 #11 Posted October 27, 2022 It uses a pull rope that latches on the square in the center of the bucket. Shown is in dump mode. 1 Share this post Link to post Share on other sites
Bow_Extreme 580 #12 Posted November 24, 2022 (edited) I’m still waiting. I’m looking for the $500 you owe me or the weight sets that you promised to ship last week. So far you’ve tried to block me from social media platforms that you exist on. My patience is wearing thin and you can make this right. Edited November 24, 2022 by Bow_Extreme Share this post Link to post Share on other sites
