Alex from GA 3 #1 Posted October 16, 2022 I've been looking for several weeks to find the correct belt and am not sure what length and or part # I need. It's a 212H with a 37" side discharge deck # 3537SL02. Thanks, Alex 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,510 #2 Posted October 16, 2022 Click on the picture in the link. Belt is on the page that comes up Share this post Link to post Share on other sites
Alex from GA 3 #3 Posted October 16, 2022 Thanks ordered it. It was one of the ones I found but wasn't sure. Share this post Link to post Share on other sites
peter lena 10,090 #4 Posted October 16, 2022 @Alex from GA suggestion , go over all / every part of that belt drive set up . chances are you will find a related pulley or rusty movement point that has been hampering this set up , you are right there , look for ease of function , grease spindles ? nylon slide belt tensioner ? pete Share this post Link to post Share on other sites
Alex from GA 3 #5 Posted October 16, 2022 Thanks. The mower is working fine; the only thing is it seems to slip with heavy grass and there's a 2" square hole in the top of the deck. I will grease the spindles and check the idler pulley when I change the belt. I'll JB Weld a piece of metal on the hole. Share this post Link to post Share on other sites
