Bow_Extreme 582 #1 Posted October 11, 2022 Coming along! Harbor Freight, Bauer Heat Gun & Wirefly 4:1, sealant lined, shrink wrap. Nice and clean. 1 4 Share this post Link to post Share on other sites
ebinmaine 78,830 #2 Posted October 11, 2022 3 minutes ago, Bow_Extreme said: Nice and clean. I 🐻 approve of this work. Well done 👍 1 1 Share this post Link to post Share on other sites
WHX?? 56,594 #3 Posted October 11, 2022 (edited) You might be the only other guy I know that does flag terms. Bet Squonky does too. Edited October 11, 2022 by WHX?? 2 Share this post Link to post Share on other sites
Bow_Extreme 582 #4 Posted October 11, 2022 10 minutes ago, WHX?? said: You might be the only other guy I know that does flag terms. Bet Squonky does too. Trying to keep this one original. 2 Share this post Link to post Share on other sites
Pullstart 69,955 #5 Posted October 12, 2022 Your name looks great in red by the way Matt! 3 Share this post Link to post Share on other sites
ebinmaine 78,830 #6 Posted October 12, 2022 11 hours ago, WHX?? said: flag terms. Not sure I knew those existed until now. It would be some handy behind a gas tank on the ignition switch of a C series or older stuff 1 Share this post Link to post Share on other sites
Bow_Extreme 582 #7 Posted October 12, 2022 17 minutes ago, Pullstart said: Your name looks great in red by the way Matt! it was time. Been here forever and a day. I apologize for the delay. 4 Share this post Link to post Share on other sites
Bow_Extreme 582 #8 Posted October 12, 2022 (edited) 1 hour ago, ebinmaine said: Not sure I knew those existed until now. It would be some handy behind a gas tank on the ignition switch of a C series or older stuff There’s a fair amount of older stuff out there that has this. The big problem with these was usually water and elements penetration at the crimp. With the sealed shrink wrap and the connector packed with di-electric grease, that should no longer be an issue. Edited October 12, 2022 by Bow_Extreme 2 1 1 Share this post Link to post Share on other sites
ebinmaine 78,830 #9 Posted October 12, 2022 26 minutes ago, Bow_Extreme said: With the sealed shrink wrap and the connector packer with di-electric grease, that should no longer be an issue. Agreed. That's how I build all my own harnesses too. Nice to see somebody doing it right. I hear @WHX?? Has a good quality love-hate relationship with Scotchlocs. 4 Share this post Link to post Share on other sites
953 nut 66,058 #10 Posted October 12, 2022 Delphi Packard 56 terminals will make a superior connection and are worth the extra expense on anything you plan to keep. They also fit into the terminal blocks used 4 Share this post Link to post Share on other sites
squonk 46,559 #11 Posted October 12, 2022 12 hours ago, WHX?? said: You might be the only other guy I know that does flag terms. Bet Squonky does too. Used to do the "Bare nekid " ones! 1 Share this post Link to post Share on other sites
Bow_Extreme 582 #12 Posted October 12, 2022 9 minutes ago, 953 nut said: Delphi Packard 56 terminals will make a superior connection and are worth the extra expense on anything you plan to keep. They also fit into the terminal blocks used 100% agreed. I use them in original restorations only or where that’s all that will work. I prefer Deutsch connectors as they are weather tight and heavy duty. Share this post Link to post Share on other sites
peter lena 9,885 #13 Posted October 12, 2022 @Bow_Extreme can appreciate the original concept , also the shrink wrapping , very efficient , where I would draw the line is wiring layout , avoid tight binding areas , keep hot spots in an air flow area , increase , verify , grounding thru the battery cable ground bolt point , add on bolt electrical lugs , to connection areas . just a suggestion / opportunity , pete 1 Share this post Link to post Share on other sites
ebinmaine 78,830 #14 Posted October 12, 2022 5 minutes ago, Bow_Extreme said: Deutsch connectors Matt can you show a picture of that? Share this post Link to post Share on other sites
WHX?? 56,594 #15 Posted October 12, 2022 (edited) 2 hours ago, ebinmaine said: Not sure I knew those existed until now. It would be some handy behind a gas tank on the ignition switch of a C series or older stuff Real handy EB. .. will get a pic of the proper crimper when I get out to the shop. 1 hour ago, ebinmaine said: I hear @WHX?? Has a good quality love-hate relationship with Scotchlocs. That's Dan's @Achto fetish.... mine is ty wraps... Edited October 12, 2022 by WHX?? 1 Share this post Link to post Share on other sites
WHX?? 56,594 #16 Posted October 12, 2022 1 hour ago, Bow_Extreme said: connector packed with di-electric grease, No coaching needed ther Pete... 1 Share this post Link to post Share on other sites
ebinmaine 78,830 #17 Posted October 12, 2022 35 minutes ago, WHX?? said: mine is ty wraps I use those. I like those. Zip ties are my friend. Share this post Link to post Share on other sites
Achto 31,794 #18 Posted October 12, 2022 1 hour ago, ebinmaine said: I hear @WHX?? Has a good quality love-hate relationship with Scotchlocs. When ever I'm over to Jim's, I like to dig through his connector bin & throw away any Scotch locks that I find. 4 Share this post Link to post Share on other sites
ebinmaine 78,830 #19 Posted October 12, 2022 8 minutes ago, Achto said: When ever I'm over to Jim's, I like to dig through his connector bin & throw away any Scotch locks that I find. You're a good friend Dan. 1 2 Share this post Link to post Share on other sites
Bow_Extreme 582 #20 Posted October 12, 2022 2 hours ago, ebinmaine said: Matt can you show a picture of that? 2 1 Share this post Link to post Share on other sites
Achto 31,794 #21 Posted October 12, 2022 (edited) Deutsch connector!!! Far superior to any factory plug that used. Edited October 12, 2022 by Achto 2 Share this post Link to post Share on other sites
peter lena 9,885 #22 Posted October 12, 2022 @Bow_Extreme also use these , peel and stick , really stick to clean paint ,https://www.amazon.com/Kontrol-Adhesive-Multi-Purpose-Mounting-Management/dp/B079G711XN/ref=sr_1_1_sspa? or use the screw hole . relieve any wire stress or chafing spots , also use cable wrap , might find them at a local electronic shop , pete 1 Share this post Link to post Share on other sites
Bow_Extreme 582 #23 Posted October 12, 2022 37 minutes ago, peter lena said: @Bow_Extreme also use these , peel and stick , really stick to clean paint ,https://www.amazon.com/Kontrol-Adhesive-Multi-Purpose-Mounting-Management/dp/B079G711XN/ref=sr_1_1_sspa? or use the screw hole . relieve any wire stress or chafing spots , also use cable wrap , might find them at a local electronic shop , pete I have a couple large bags of these. 1 Share this post Link to post Share on other sites
WHX?? 56,594 #24 Posted October 12, 2022 (edited) Guessing thats the crimper I need for these? For repairing the connectors on the horse hauler fuel station that got ripped out when a tire blew. I was going to solder them on but wouldn't be beyond having a set. What kind of power/ampss can Deutch connectors handle.? Looks like we have the same strippers Matt. These do work really slick. Edited October 12, 2022 by WHX?? 2 Share this post Link to post Share on other sites
Achto 31,794 #25 Posted October 12, 2022 3 minutes ago, WHX?? said: Guessing thats the crimper I need for these? Actually you need this style for those ends. https://www.amazon.com/TUBTAP-Crimping-Connectors-0-5-1-5mm²-Terminal/dp/B09GYFKT6F One of these will do the trick as well. https://www.google.com/search?q=blue+point+wire+crimpers&rlz=1C1GCEU_enUS821US821&source=lnms&tbm=isch&sa=X&ved=2ahUKEwiP17vZqtv6AhXLrmoFHYuFAG4Q_AUoAnoECAEQBA&biw=1920&bih=937&dpr=1#imgrc=uN7M3By97P-FQM I have this style if you need to borrow them. 2 1 Share this post Link to post Share on other sites
