Wheelhorse#1 1,901 #1 Posted October 8, 2022 Well this isn’t sounding too good.What do you think? IMG_5175.MOV Share this post Link to post Share on other sites
953 nut 64,115 #2 Posted October 8, 2022 (edited) didn't open, can you put it on YouTube and post that? Finally opened after 3 minutes. Your drive belt had quite a vibration going on, remove it and see if the knock goes away. Edited October 8, 2022 by 953 nut 2 Share this post Link to post Share on other sites
Jeff-C175 7,207 #3 Posted October 8, 2022 Has it still got the bahlahns gears in it? Share this post Link to post Share on other sites
Wheelhorse#1 1,901 #4 Posted October 9, 2022 (edited) 20 hours ago, 953 nut said: didn't open, can you put it on YouTube and post that? Finally opened after 3 minutes. Your drive belt had quite a vibration going on, remove it and see if the knock goes away. @953 nut You are 100% correct.I removed the drive belt, noise went away completely. This is the previous vid I posted of the noise it was making. https://youtube.com/shorts/hxJe58rxR4c?feature=share What baffles me is that when I put the engine under load, without the belt installed and put it under load "the bottom of my boot on the pully" Im getting the knock again at higher rpm. Bearing end play not correct ?or something else ? Shade tree refresh. new piston, rings, rod and valves and hone . Everything was just in spec. I did not check bearing end play though that's what I'm thinking.The bearings seemed fine. Any thoughts ? thx Edited October 9, 2022 by Wheelhorse#1 Share this post Link to post Share on other sites
Wheelhorse#1 1,901 #5 Posted October 10, 2022 On 10/8/2022 at 7:27 PM, Jeff-C175 said: Has it still got the bahlahns gears in it? @Jeff-C175 I removed them they were about to go,needle bearing was shot. Share this post Link to post Share on other sites
