Blasterdad 3,066 #1 Posted October 6, 2022 Finally found a 60" deck in great shape with brand new blades, used set hardly used & correct drive mule. It has a little surface rust but not bad, it will clean up nice, I can tell it was taken care of. You don't fully appreciate how big they are until you see one in person & have to move the thing by yourself. What a tank, all 350 pounds of it. 2 3 Share this post Link to post Share on other sites
Blasterdad 3,066 #2 Posted October 6, 2022 Just noticed in the pics it's cracking my cement! 8 Share this post Link to post Share on other sites
DoctorHfuhruhurr 137 #3 Posted October 6, 2022 BEEFY !!!! Share this post Link to post Share on other sites
WHX?? 53,280 #4 Posted October 6, 2022 Bigger ? is whacha gonna put it under? Share this post Link to post Share on other sites
Blasterdad 3,066 #5 Posted October 6, 2022 7 hours ago, WHX?? said: Bigger ? is whacha gonna put it under? Probably something like this... 2 Share this post Link to post Share on other sites
Ed Kennell 43,756 #6 Posted October 6, 2022 Never could understand why WH put three anti scalp wheels across the front of the 42" decks, but only put the one center wheel on many of the 48 and 60 inch decks. Probably assuming the big decks would only be used on flat lawns so why not save $50. BTW, I have added front corner wheels to my 48" deck. 2 Share this post Link to post Share on other sites
peter lena 9,552 #7 Posted October 6, 2022 @Blasterdad would make every effort to free that unit up for function , noted for terrific drag on the pto set up , think a lubrication change out / upgrade would be in order , only a suggestion , the heavy spindle drag , can be lessened . would also go after your mule drive set up , to enhance / free that up. pete Share this post Link to post Share on other sites
Blasterdad 3,066 #8 Posted October 6, 2022 7 hours ago, peter lena said: @Blasterdad would make every effort to free that unit up for function , noted for terrific drag on the pto set up , think a lubrication change out / upgrade would be in order , only a suggestion , the heavy spindle drag , can be lessened . would also go after your mule drive set up , to enhance / free that up. pete The gentleman I bought it from took very good care of it, low hours, just greased, no noise/play in the spindles, offset mule pulleys smooth as silk, new deck belt & blades. The underside has no dirt or grass on it anywhere. I'm going to double check when I take it apart & paint it, & as @Ed Kennell suggested it will be getting new scalp wheels at the front corners. 1 Share this post Link to post Share on other sites
kpinnc 16,169 #9 Posted October 7, 2022 On 10/6/2022 at 7:24 AM, Ed Kennell said: Never could understand why WH put three anti scalp wheels across the front of the 42" decks, but only put the one center wheel on many of the 48 and 60 inch decks. First gen 60s had only the center wheel. Like from the C-195 era. Then the later versions commonly found on 520-H had adjustable scalp wheels added. 1 Share this post Link to post Share on other sites
