Searcher60 209 #1 Posted October 3, 2022 Thanks in advance, you guys are great! I need to make 2 standard tilt levers for dozer blades I have. Can you tell me if the steel is 5/16” thick x 1 1/4” wide? What is the overall length? How far up from the bottom is that offset 90 deg. bend, and how wide is the offset bend? Other than that offset bend, is the lever straight from top to bottom? Thanks again! Share this post Link to post Share on other sites
daveoman1966 3,882 #2 Posted October 3, 2022 The flat stock steel bar is 5/16" x 1-1/4" wide. Here are the other dimensions. 3 Share this post Link to post Share on other sites
JCM 11,088 #3 Posted October 3, 2022 Does anyone have a similar illustration on the angle lever used with the 520-H with the front extension set up ? Share this post Link to post Share on other sites
daveoman1966 3,882 #4 Posted October 3, 2022 This is the index lever, but I don't have the dimensions...except that it is also 5/16" x 1-1/4" wide. 1 1 Share this post Link to post Share on other sites
Searcher60 209 #5 Posted October 3, 2022 Much appreciated Dave! Thanks so much, outstanding job! Share this post Link to post Share on other sites
peter lena 9,846 #6 Posted October 3, 2022 @Searcher60 , done a number of improvements on that lever set up , another thing I do is to roller stool around it while checking its function , along with its hook up point . red grease , is excellent or every movable point , note the lever pull rod response , used a small channel lock plier to snug up the pull point , eliminating play. freeing up any related point , makes that lever action , much easier . different yet related , detailed in my plow steering quadrant , swings with total ease , slide pin works like a rifle bolt , also added a male/ female heim joints on that long pull rod , pete Share this post Link to post Share on other sites
peter lena 9,846 #7 Posted October 3, 2022 @Searcher60 , also use ,https://www.amazon.com/INCREWAY-Hair-Clips-2-15-16- 54817&psc=1 these clips on your rear axel frame point , only using picture as reference , local h/w store , also push them all the way thru to last big end hole , will not fall out , pete Share this post Link to post Share on other sites
Pullstart 69,631 #8 Posted October 3, 2022 7 hours ago, daveoman1966 said: This is the index lever, but I don't have the dimensions...except that it is also 5/16" x 1-1/4" wide. I have one of those in the garage on a plow until this weekend. If there’s any measurements needed before I send it to the new owner let me know. 1 Share this post Link to post Share on other sites
Searcher60 209 #9 Posted October 3, 2022 (edited) 9 hours ago, JCM said: Does anyone have a similar illustration on the angle lever used with the 520-H with the front extension set up ? The hole measurements on the left, and eye bolt hole, are all from the left side very end, the one on the right from the very right end. All bolt hole measurements are to the center of the hole. I have a complete 520 dozer extension kit for sale, but the handle is expensive to ship due to offset and length. Edited October 4, 2022 by Searcher60 1 1 Share this post Link to post Share on other sites
Searcher60 209 #10 Posted October 4, 2022 The hole measurements on the left, and eye bolt hole, are all from the left side very end, the one on the right from the very right end. All bolt hole measurements are to the center of the hole. I have a complete 520 dozer extension kit for sale, but the handle is expensive to ship due to offset and length. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,138 #11 Posted October 4, 2022 Found this service bulletin on the subject on hydro models. Click on the fuzzy picture in the link and again on the page that comes up. Share this post Link to post Share on other sites
