huey 7 #1 Posted October 1, 2022 (edited) Just wondering what blades are most popular for 48" side discharge and also 60" deck. I'm needing to replace my blades and not sure what to get! Edited October 1, 2022 by huey Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,450 #2 Posted October 2, 2022 You maty not have a lot of choices. Blade length and center hole are the main requirements. Best to do a Goggle search using the original Toro part numbers and see what pops up. If Stens has a replacement it should come up here using the original Toro number https://www.rcpw.com/ 1 Share this post Link to post Share on other sites
Jeff-C175 7,211 #3 Posted October 2, 2022 On 10/1/2022 at 6:24 PM, huey said: blades One thing to watch out for: In some cases, depending on the condition of the deck, how 'bent' it might be, the 'lift wing' on the blade may hit the rear apron of the deck so make sure to check this if you plan to use a 'high lift' blade! 2 Share this post Link to post Share on other sites
