TJ5208 1,841 #1 Posted September 28, 2022 What angle of pipe do i need to have to have a exhaust system like this. Share this post Link to post Share on other sites
JimSraj 550 #2 Posted September 28, 2022 The iron pipe looks like a 22-1/2 and a 90 plus the nipples to connect. 1 Share this post Link to post Share on other sites
TJ5208 1,841 #3 Posted September 28, 2022 1 minute ago, JimSraj said: The iron pipe looks like a 22-1/2 and a 90 plus the nipples to connect. What about the bend in the middle. Share this post Link to post Share on other sites
Handy Don 14,665 #4 Posted September 28, 2022 (edited) 18 hours ago, TJ Salyers said: What about the bend in the middle. The 22½ is a female to female elbow - 45º (edited!) Edited September 28, 2022 by Handy Don 1 Share this post Link to post Share on other sites
TJ5208 1,841 #5 Posted September 28, 2022 1 minute ago, Handy Don said: Looks to be a 45º coupler I want to do this setup on my Raider 14 and I like how the exhaust goes straight out not at a angle. Share this post Link to post Share on other sites
Handy Don 14,665 #6 Posted September 28, 2022 (edited) 18 hours ago, TJ Salyers said: I want to do this setup on my Raider 14 and I like how the exhaust goes straight out not at a angle. (comment removed) Also, it'll need a support bracket -- you cannot safely support that from the block only. Edited September 28, 2022 by Handy Don Share this post Link to post Share on other sites
TJ5208 1,841 #7 Posted September 28, 2022 (edited) 3 minutes ago, Handy Don said: Note i edited my response. 22 ½, not 45. Also, it'll need a support bracket -- you cannot safely support that from the block only. I could make a support to the frame. Edited September 28, 2022 by TJ Salyers Share this post Link to post Share on other sites
JimSraj 550 #8 Posted September 28, 2022 That’s the 22-1/2 if I’m looking at it right. Looks like a 3” nipple out of the block, then the 22-1/2, then a 2” nipple into a 90 into another 3” nipple to the muffler. Agree on additional support. 2 Share this post Link to post Share on other sites
TJ5208 1,841 #9 Posted September 28, 2022 10 hours ago, JimSraj said: That’s the 22-1/2 Is that a 45 degree angle? Share this post Link to post Share on other sites
twisted metal 49 #10 Posted September 28, 2022 Yes it's a 45 degree angle. They only make 45 and 90 degree threaded pipe fittings. Share this post Link to post Share on other sites
lynnmor 8,089 #11 Posted September 28, 2022 46 minutes ago, TJ Salyers said: Is that a 45 degree angle? 22-1/2 is half of 45, basic geometry. Share this post Link to post Share on other sites
rmaynard 16,589 #12 Posted September 28, 2022 I've never understood why someone would want a stack on a garden tractor. 4 3 Share this post Link to post Share on other sites
wallfish 18,627 #13 Posted September 28, 2022 (edited) This thread is confusing. Both the 22 1/2 thing and why anyone wants a stack. LoL The exhaust port coming out of the Kohler engine is at 45 deg, That pipe nipple exiting the exhaust port goes into a 45 deg fitting, Then to a 90 deg fitting to turn it straight up The angle the pic is taken might be at 22 1/2 deg Edited September 28, 2022 by wallfish 2 Share this post Link to post Share on other sites
squonk 44,636 #14 Posted September 28, 2022 Yup 45° +45° =90° If you managed to find a 22 1/2 the pipe would come out at a funky angle towards the front corner of the hood. Share this post Link to post Share on other sites
Jeff-C175 7,206 #15 Posted September 28, 2022 Just for completeness sake, the pipe thread is 1" IPS. You can brace to frame as long as it's not a shaker plate. 2 Share this post Link to post Share on other sites
953 nut 62,189 #16 Posted September 28, 2022 If you replace the 90 with a 1" X 1/2" X 1" black iron "T" and drill and tap a 1/2" pipe plug for 1/4-20 the brace can be put under the added weight. 5 2 Share this post Link to post Share on other sites
JimSraj 550 #17 Posted September 29, 2022 Nice brace idea 💡 953nut! 2 Share this post Link to post Share on other sites
TJ5208 1,841 #18 Posted September 29, 2022 4 hours ago, squonk said: Yup 45° +45° =90° If you managed to find a 22 1/2 the pipe would come out at a funky angle towards the front corner of the hood. Thats what i meant the angle towards the front of the hood i dont want that. Share this post Link to post Share on other sites
953 nut 62,189 #19 Posted September 29, 2022 10 hours ago, TJ Salyers said: Thats what i meant the angle towards the front of the hood i dont want that. If you want the stack a bit further back you could eliminate the short nipple and F X F 45 and use a 1" black iron Street 45 right off the engine. 1 Share this post Link to post Share on other sites
TJ5208 1,841 #20 Posted September 29, 2022 (edited) 4 hours ago, 953 nut said: If you want the stack a bit further back you could eliminate the short nipple and F X F 45 and use a 1" black iron Street 45 right off the engine. Have you did this to your tractors? Do you have pics? Edited September 29, 2022 by TJ Salyers Share this post Link to post Share on other sites
TJ5208 1,841 #21 Posted September 29, 2022 (edited) Would someone post some pics of there stacks on a 14 hp Kohler with the same setup as in post #1 or in post #19. Edited September 29, 2022 by TJ Salyers Share this post Link to post Share on other sites
TJ5208 1,841 #24 Posted September 29, 2022 (edited) 2 hours ago, squonk said: How does it look? Edited September 29, 2022 by TJ Salyers 1 Share this post Link to post Share on other sites
squonk 44,636 #25 Posted September 29, 2022 (edited) 17 minutes ago, TJ Salyers said: How does it look? Just like the other pic I sent. Just a different tractor and a smaller muffler. Edited September 29, 2022 by squonk 1 Share this post Link to post Share on other sites
