953 nut 67,376 #51 Posted October 31, 2022 Looks like a previous owner had a pipe bender. You may be able to pick up a seat frame on . https://www.ebay.com/itm/225029250103?hash=item3464c9dc37&amdata=enc%3AAQAHAAABAIN1FkHXEycXeMU%2B%2B1MkPG4nRjeH%2FkwmIphQfxlRmjQeBTdfjIf2SJPPDOPCmR6ZDc6nSad5vPkli1O41nG%2B2BXO3P1cJzQmOgpcuotvFe%2FmgtcmxghXnzl9C9SUSqIZkBSVrzTHTuOv%2Fp%2BtenidN8IbwOzZjuqJjfdADXQYfqKTRKfbci0J%2B8IH5hMMgXdUSenlPWCOP0ZNAU3GQ129ZIol5JynXvSfqpc223JArd2lyKmwqvT0kBjpqFcS4Hofv3Uno8FrSOxTTFi9FIYeGPfAxqna6duJu8k2E5Oxfi1tDcJ7%2BuUjQBn8kFtB9j1ihWgMGhkpEQ6CF2akosBRYao%3D|ampid%3APL_CLK 2 Share this post Link to post Share on other sites
marreque 218 #52 Posted November 5, 2022 Before I forget 5 Share this post Link to post Share on other sites
marreque 218 #53 Posted November 6, 2022 Happy Sunday It seems the ACR isn't working......any suggestions???? 2 Share this post Link to post Share on other sites
ebinmaine 79,649 #54 Posted November 6, 2022 That's at or near the beginning of acr. Was it originally built with it? Why do you think it isn't working? Turning over hard/very slowly? 1 Share this post Link to post Share on other sites
marreque 218 #55 Posted November 6, 2022 Very difficult to turn over, I actually have to help it by turning the crank by hand 2 Share this post Link to post Share on other sites
marreque 218 #56 Posted November 6, 2022 Is there anything that can be do to help it? I pulled the cam cover and I don't see any sign of a ACR. 2 Share this post Link to post Share on other sites
ebinmaine 79,649 #57 Posted November 6, 2022 1 hour ago, marreque said: Is there anything that can be do to help it? I pulled the cam cover and I don't see any sign of a ACR. Has the starter generator been rebuilt? Are ALL the wiring connections in very good clean condition? In particular the battery cables.. Is the battery good and strong? 1 Share this post Link to post Share on other sites
marreque 218 #58 Posted November 6, 2022 All new wires and cables, the starter/generator has not been touched. 2 Share this post Link to post Share on other sites
ebinmaine 79,649 #59 Posted November 7, 2022 Might be time to address the S/G. Isavetractors YouTube channel has a very good rebuild tutorial on them. Any chance you have a spare S/G to swap in? 1 Share this post Link to post Share on other sites
953 nut 67,376 #60 Posted November 7, 2022 Is the belt from the S/G to the engine a notched raw rubber edge belt, it not it will not deliver as much power to turn over the engine. 3 Share this post Link to post Share on other sites
marreque 218 #61 Posted November 7, 2022 11 hours ago, ebinmaine said: Might be time to address the S/G. Isavetractors YouTube channel has a very good rebuild tutorial on them. Any chance you have a spare S/G to swap in? I do not but I have watched his S/G rebuild video, going to order the rebuild kit. 3 Share this post Link to post Share on other sites
marreque 218 #62 Posted November 7, 2022 10 hours ago, 953 nut said: Is the belt from the S/G to the engine a notched raw rubber edge belt, it not it will not deliver as much power to turn over the engine. Not sure about the belt, I'll take a look and replace it with a notched one. I'll assume the picture is the correct one from Napa or for reference purposes only?? 5 Share this post Link to post Share on other sites
953 nut 67,376 #63 Posted November 7, 2022 Yes, that is the correct belt for 10 to 14 HP S?G Kohler engines. 4 Share this post Link to post Share on other sites
marreque 218 #64 Posted November 7, 2022 8 hours ago, 953 nut said: Thank you!! 3 Share this post Link to post Share on other sites
marreque 218 #65 Posted November 9, 2022 So I ordered a S/G rebuild kit and will pick up the correct belt..... hopefully this works!!! 4 Share this post Link to post Share on other sites
marreque 218 #66 Posted November 9, 2022 It better work, I really want to use this tractor!!! If anyone knows where I can get a mowing deck please let me know, thank you 2 Share this post Link to post Share on other sites
ebinmaine 79,649 #67 Posted November 9, 2022 4 minutes ago, marreque said: It better work, I really want to use this tractor!!! If anyone knows where I can get a mowing deck please let me know, thank you Wouldn't hurt to post a "wanted" ad in our classified section. Also do feel free to post a thread in Implements to see what other model's deck might work. 4 Share this post Link to post Share on other sites
953 nut 67,376 #68 Posted November 9, 2022 11 hours ago, marreque said: It better work, I really want to use this tractor!!! If anyone knows where I can get a mowing deck please let me know, thank you If you come to the Big Show in June there is bound to be a deck or two for the 953/1054 there. 2 Share this post Link to post Share on other sites
marreque 218 #69 Posted November 9, 2022 5 hours ago, 953 nut said: If you come to the Big Show in June there is bound to be a deck or two for the 953/1054 there. I was planning on going…..wha the dates for 2013?? 2 Share this post Link to post Share on other sites
953 nut 67,376 #70 Posted November 9, 2022 1 hour ago, marreque said: I was planning on going…..wha the dates for 2013?? Set up day and best day to find what you want to buy. June 22; show dates June 23 and 24 1 2 Share this post Link to post Share on other sites
marreque 218 #71 Posted November 27, 2022 Came up on a box of parts today. Had the factory throttle lever in it with the white knob and what I believe may be the Gen light... 3 Share this post Link to post Share on other sites
953 nut 67,376 #72 Posted November 27, 2022 1 hour ago, marreque said: I believe may be the Gen light. That is your generator light, large terminal goes to the starter button on the post that feeds the S/G "A" post , the other wire goes to the key switch post that goes to the ignition coil. 2 Share this post Link to post Share on other sites
marreque 218 #73 Posted November 27, 2022 Thank you, will be needing a new bulb...#53 is what's in it now. 1 Share this post Link to post Share on other sites
marreque 218 #74 Posted April 10, 2023 Update and a thanks for the help guys. Finally got some time to work on the 1054 today. Taking 953 nuts advice I purchased the correct s/g belt and also rebuilt the s/g. It cranks over much easier now and she fired right up. I took it for a ride for the first time since 96-97. Everything seems fine except full throttle is definitely not full throttle. Any help or ideas would be great as always!!! 1 3 Share this post Link to post Share on other sites
Wayne0 1,573 #75 Posted April 11, 2023 (edited) On 11/8/2022 at 7:55 PM, marreque said: It better work, I really want to use this tractor!!! If anyone knows where I can get a mowing deck please let me know, thank you Never mind Edited April 11, 2023 by Wayne0 Brain fart 1 Share this post Link to post Share on other sites
