davidfindlay 51 #1 Posted September 23, 2022 (edited) My 1984 B Series has been underpowered lately and I just noticed this when I ran it with the engine exposed. Any suggestion as to what I can do about it? FullSizeRender.MOV Edited September 23, 2022 by davidfindlay Hadn’t finished typing 1 1 Share this post Link to post Share on other sites
Heatingman 977 #2 Posted September 23, 2022 (edited) You need a new head for that motor. With a breach in the head, you wont develop much compression, and inturn low power. If you can weld, that may buy you some time, but no guarantee. Edited September 23, 2022 by Heatingman 4 Share this post Link to post Share on other sites
ebinmaine 80,294 #3 Posted September 23, 2022 6 hours ago, davidfindlay said: 1984 B Series That looks like a Tecumseh engine. Wouldn't have been used in either a B series which was 1974-77 with a horizontal shaft... Or a 1984 anything. Do you have model numbers of the tractor or engine? 4 hours ago, Heatingman said: You need a new head for that Could the head be warped enough and/or the gasket blown out to cause that? Share this post Link to post Share on other sites
Ed Kennell 46,987 #4 Posted September 23, 2022 to the David. Call Lincoln at @A-Z Tractor for a new head. Share this post Link to post Share on other sites
Pullstart 71,101 #5 Posted September 23, 2022 Wow! I’ve never seen anything like that! Share this post Link to post Share on other sites
davidfindlay 51 #6 Posted September 23, 2022 (edited) Thank you for all the replies. It didn’t occur to me to mention which engine it was when I posted last night, sorry. Edited September 23, 2022 by davidfindlay Image 1 Share this post Link to post Share on other sites
ebinmaine 80,294 #7 Posted September 23, 2022 3 minutes ago, davidfindlay said: Thank you for all the replies. It didn’t occur to me to mention which engine it was when I posted last night, sorry. That's not the same engine as what's in the video that my phone downloads... Irregardless to that. Have you had the head off? Check the cylinder head gasket? Hand planed the cylinder head? 1 Share this post Link to post Share on other sites
davidfindlay 51 #8 Posted September 23, 2022 4 minutes ago, ebinmaine said: That's not the same engine as what's in the video that my phone downloads... It is, I just cropped the video. 4 minutes ago, ebinmaine said: Irregardless to that. Have you had the head off? Check the cylinder head gasket? Hand planed the cylinder head? I haven't done anything to try and fix it yet no. Do I need any special tools to take it off? (I have various general tools and a couple of socket sets but not any specialized mechanic tools.) 1 Share this post Link to post Share on other sites
ebinmaine 80,294 #9 Posted September 23, 2022 1 minute ago, davidfindlay said: . Do I need any special tools to take it off? (I have various general tools and a couple of socket sets but not any specialized mechanic tools.) No no. You'll be fine with that. That's all nuts and bolts type stuff. To reinstall the head you're going to need a torque wrench. Hand flattening of a cylinder head can be done by pretty much anyone. It's a bit time-consuming but it's easy to do. You need a very flat surface like a piece of Steel or thick glass that you can take sandpaper to. First things first of course though. You'll need to get it disassembled and get some more pictures so we can see what the actual defect is. 2 Share this post Link to post Share on other sites
davidfindlay 51 #10 Posted September 23, 2022 1 minute ago, ebinmaine said: No no. You'll be fine with that. That's all nuts and bolts type stuff. Great! 1 minute ago, ebinmaine said: To reinstall the head you're going to need a torque wrench. I have one of those, fortunately. 1 minute ago, ebinmaine said: Hand flattening of a cylinder head can be done by pretty much anyone. It's a bit time-consuming but it's easy to do. You need a very flat surface like a piece of Steel or thick glass that you can take sandpaper to. First things first of course though. You'll need to get it disassembled and get some more pictures so we can see what the actual defect is. Will do, thanks for the advice. 3 Share this post Link to post Share on other sites
Heatingman 977 #11 Posted September 23, 2022 You will need a torque wrench to reinstall the repaired/new head. 15 to 20 ft lbs if memory serves for those head bolts 1 Share this post Link to post Share on other sites
davidfindlay 51 #12 Posted September 23, 2022 7 minutes ago, Heatingman said: You will need a torque wrench to reinstall the repaired/new head. 15 to 20 ft lbs if memory serves for those head bolts Thanks. I have a PDF of the service manual. I looked just now and found the "Cylinder Head Fastener Torque Sequence" figure in there. For K161/181 it says 15-20 ft. lbs. but for K241/K301/K321/K341 it says 25-30 ft. lbs. 4 Share this post Link to post Share on other sites
Snoopy11 5,731 #13 Posted September 23, 2022 Expensive new: https://isavetractors.com/cylinder-head-for-kohler-k241-k301-k321-m10-m12-m14-engines/ Cheap used: https://www.ebay.com/itm/134244386079?hash=item1f4196c51f:g:6kQAAOSw-8pjK5k6&amdata=enc%3AAQAHAAAAoDmHkvdcLgcw6QRkMpGE%2FHNaAhozMlJPlDk5HAqm8jkUuoULQ%2BBh9tFXI%2FaDpWvhejJL2jcVWUCusUgEpmnDBjkE4OBcqnEGMD4bwb0L5YN9Om3u91cUFMfhCbLhyWWd7AO2Ft0Gd5ugyHwSybj1LUGxtDKkeHFT4FIY1WZ3Dub0GJYM%2BYjB2H8YbA1fsBvQq%2FVAXc7HgwEzmZfxSxQ9c%2FA%3D|tkp%3ABk9SR8yA1K_tYA Don 2 Share this post Link to post Share on other sites
ebinmaine 80,294 #14 Posted September 23, 2022 3 minutes ago, Snoopy11 said: used: It's important to remember that the bolts included in that package should not be used because you don't know the history of them. Also, that used cylinder head will still need to be hand planed. I would absolutely not recommend buying anything at all until disassembly and diagnosis has been completed and agreed upon. I would recommend buying from Lincoln at A to Z if possible which is an approved vendor of Red Square. 6 Share this post Link to post Share on other sites
The Freightliner Guy 1,364 #15 Posted September 23, 2022 Great advice EB like you said you don’t know what condition those bolts are or have been in 2 Share this post Link to post Share on other sites
pacer 3,180 #16 Posted September 23, 2022 I agree in that - do not buy a new head or ... really anything til you get that off and get us a couple good pics (like the ones youve already made) so it can be determined just what is going on. And as mentioned removal of the head is truly simple, maybe half hour. 3 Share this post Link to post Share on other sites
Snoopy11 5,731 #17 Posted September 23, 2022 8 minutes ago, ebinmaine said: I would recommend buying from Lincoln at A to Z if possible which is an approved vendor of Red Square. Yessir... I was just letting the OP know that there are options... so hopefully the OP won't give up on this old engine! Don 3 Share this post Link to post Share on other sites
davidfindlay 51 #18 Posted September 23, 2022 3 minutes ago, Snoopy11 said: Yessir... I was just letting the OP know that there are options... so hopefully the OP won't give up on this old engine! Don I definitely don't want to give up on it: this has been the best tractor I've had. 3 2 Share this post Link to post Share on other sites
ebinmaine 80,294 #19 Posted September 23, 2022 Just now, davidfindlay said: I definitely don't want to give up on it: this has been the best tractor I've had. OF COURSE IT IS !!! 1 2 1 Share this post Link to post Share on other sites
davidfindlay 51 #20 Posted September 23, 2022 6 minutes ago, pacer said: I agree in that - do not buy a new head or ... really anything til you get that off and get us a couple good pics (like the ones youve already made) so it can be determined just what is going on. And as mentioned removal of the head is truly simple, maybe half hour. I have to work today but will try and get the head off over the weekend. 2 Share this post Link to post Share on other sites
squonk 47,888 #21 Posted September 23, 2022 If you need a head, I have one PM if needed 1 2 2 Share this post Link to post Share on other sites
The Freightliner Guy 1,364 #22 Posted September 23, 2022 Oh look squonker has one how nice of him truely Share this post Link to post Share on other sites
Snoopy11 5,731 #23 Posted September 23, 2022 3 minutes ago, squonk said: If you need a head, I have one PM if needed Addendum that you should add to that, Mike. You only get the cylinder head if you become a supporter on the forum. Don 1 Share this post Link to post Share on other sites
davidfindlay 51 #24 Posted September 23, 2022 6 minutes ago, Snoopy11 said: Addendum that you should add to that, Mike. You only get the cylinder head if you become a supporter on the forum. Don Absolutely. 2 Share this post Link to post Share on other sites
95 Truck 17 #25 Posted September 23, 2022 After watching video and seeing where the lighting show is taking place, then looking at head posted, you sir will need the head offered up. It looks to be cracked or burned thru. As some else said it will explain your low on power statement. 2 Share this post Link to post Share on other sites
