WHX?? 57,808 #26 Posted September 20, 2022 9 minutes ago, ebinmaine said: What's an AED? A jump pack dingus... 1 Share this post Link to post Share on other sites
Pullstart 71,103 #27 Posted September 20, 2022 32 minutes ago, WHX?? said: Be interesting just to see if it runs?!?! After further review what the heck is that belt on the mower? 3 minutes ago, Achto said: Adjustable link drive belt. https://www.grainger.com/product/POWERTWIST-STANDARD-Link-V-Belt-Powertwist-Std-49YL71?opr=IDPPLARECS&analytics=PLAPDP_undefined after further review, does the PTO release go that far back on a Lawn Ranger? 1 Share this post Link to post Share on other sites
Pullstart 71,103 #28 Posted September 20, 2022 1 minute ago, ebinmaine said: One of the several 8 HP Kohler engines we've seen here had the old rubber fuel hose go through the shroud kind of at the bottom of the cooling fins. I cut space for mine, and sleeved it with a steel tube 1 Share this post Link to post Share on other sites
Achto 32,347 #29 Posted September 20, 2022 2 minutes ago, Pullstart said: What where the terms of acquisition? It was in the 2 digit range. 1 1 Share this post Link to post Share on other sites
ebinmaine 80,306 #30 Posted September 20, 2022 Just now, Achto said: It was in the 2 digit range. Custom one of a kind front hitch worth that. 1 1 1 Share this post Link to post Share on other sites
Pullstart 71,103 #31 Posted September 20, 2022 So is there a body lift on it to clear the big block Tecky? 1 Share this post Link to post Share on other sites
ebinmaine 80,306 #32 Posted September 20, 2022 2 minutes ago, Pullstart said: I cut space for mine, and sleeved it with a steel tube Mine was neither. I believe it was on the first Horse. My B80. My favorite small engine shop assembled most of it. Not sure why they thought it went in there but it worked. 1 Share this post Link to post Share on other sites
Pullstart 71,103 #33 Posted September 21, 2022 Just now, ebinmaine said: Mine was neither. I believe it was on the first Horse. My B80. My favorite small engine shop assembled most of it. Not sure why they thought it went in there but it worked. Between the backing plate and the cooling fins? I think I’ve got a couple more like that too… 1 Share this post Link to post Share on other sites
Achto 32,347 #34 Posted September 21, 2022 (edited) 5 minutes ago, Pullstart said: does the PTO release go that far back on a Lawn Ranger? Drops forward to release. Ain't owned one o dese fer. Whole things a bit mystery to me yet Edited September 21, 2022 by Achto Share this post Link to post Share on other sites
Achto 32,347 #35 Posted September 21, 2022 (edited) 3 minutes ago, Pullstart said: So is there a body lift on it to clear the big block Tecky? A bit yes. Plus the hacking on the sides of the hood. Edited September 21, 2022 by Achto 1 Share this post Link to post Share on other sites
WHX?? 57,808 #36 Posted September 21, 2022 Just now, Achto said: It was in the 2 digit range. In other words Kev he it. Nothin else parts is parts ... I'm already eyeballin the hood for shop art... Nawww we already had a high level executive meeting about it it so possibly a RR. 2 1 Share this post Link to post Share on other sites
ebinmaine 80,306 #37 Posted September 21, 2022 2 minutes ago, Pullstart said: Between the backing plate and the cooling fins? Yeah ya know that might be... 1 Share this post Link to post Share on other sites
TJ5208 1,841 #38 Posted September 21, 2022 The Raider 10 we have has the fuel line throught the shroud. 1 Share this post Link to post Share on other sites
TJ5208 1,841 #39 Posted September 21, 2022 One reason I don't like Tecumseh they don't even make the horsepower there rated at. Compare both of the 160s and you'll see why. 2 Share this post Link to post Share on other sites
WHX?? 57,808 #40 Posted September 21, 2022 5 minutes ago, WHX?? said: possibly a RR. Yeah... that's it ... a predator that screams at 10k rpm, Dan's vision for body work & accoutrements... replace the hitch with rear weights just to keep the front off the ground... 2 Share this post Link to post Share on other sites
WHX?? 57,808 #41 Posted September 21, 2022 2 minutes ago, WHX?? said: rear weights just to keep the front off the ground... OK... add steering brakes... 1 Share this post Link to post Share on other sites
Achto 32,347 #42 Posted September 21, 2022 4 minutes ago, WHX?? said: add steering brakes No sense of adventure. Full throttle till you see God, then hope the brakes work. 1 3 Share this post Link to post Share on other sites
TJ5208 1,841 #43 Posted September 21, 2022 Just now, Achto said: No sense of adventure. Full throttle till you see God, then hope the brakes work. Then God said welcome home my child. 4 Share this post Link to post Share on other sites
ebinmaine 80,306 #44 Posted September 21, 2022 10 minutes ago, TJ Salyers said: One reason I don't like Tecumseh they don't even make the horsepower there rated at. Compare both of the 160s and you'll see why. I don't see ... They both make 16. 3 Share this post Link to post Share on other sites
TJ5208 1,841 #45 Posted September 21, 2022 2 minutes ago, ebinmaine said: I don't see ... They both make 16. The piston displacements are way different. Share this post Link to post Share on other sites
ebinmaine 80,306 #46 Posted September 21, 2022 Just now, TJ Salyers said: The piston displacements are way different. Absolutely true. The Tecumseh is an overhead valve engine. It makes the same amount of HP with less displacement. It is less torque. But HP is identical. For the size ... the Tecumseh is pretty stout. 3 1 Share this post Link to post Share on other sites
squonk 47,890 #47 Posted September 21, 2022 (edited) All the Tecky's I blew up in my life had the fuel line through the shroud. Edited September 21, 2022 by squonk 3 Share this post Link to post Share on other sites
Achto 32,347 #48 Posted September 21, 2022 Just now, TJ Salyers said: 4 minutes ago, ebinmaine said: The piston displacements are way different. While I'm a firm believer in "There's no replacement for displacement" It is not untrue that you can just as much Horse Power out of a Honda 2.2L engine as you can out of a Chev 5.7L engine. Torque may be a different story. 2 Share this post Link to post Share on other sites
TJ5208 1,841 #49 Posted September 21, 2022 Just now, Achto said: While I'm a firm believer in "There's no replacement for displacement" It is not untrue that you can just as much Horse Power out of a Honda 2.2L engine as you can out of a Chev 5.7L engine. Torque may be a different story. So this mean I'm wrong? Share this post Link to post Share on other sites
Achto 32,347 #50 Posted September 21, 2022 1 minute ago, TJ Salyers said: So this mean I'm wrong? Both the Techy and the Kohler produce 16hp according to the manufacturers. Torque may be different though. 1 Share this post Link to post Share on other sites
