oliver2-44 8,874 #1 Posted September 19, 2022 Picked up a tractor this weekend and these weights came with it, but they certainly don't a 701. They have white paint with yellow paint underneath. There are no through bolt holes in them. but, on the back side there are four 5/16 threaded holes which seem small. They are 11" in diameter with the notch on the side, and they weigh 50 pounds each. 1 Share this post Link to post Share on other sites
Pullstart 59,825 #2 Posted September 19, 2022 Maybe homemade, for a IH Cub front? Share this post Link to post Share on other sites
Achto 26,608 #3 Posted September 20, 2022 (edited) They look like brake drums filled with some thing. If you can get the treaded holes to line up with the 4 square holes in the center of the rim they should work. Weight is weight in my opinion. Edited September 20, 2022 by Achto 1 Share this post Link to post Share on other sites
ri702bill 7,362 #4 Posted September 20, 2022 7 hours ago, Achto said: They look like brake drums filled with some thing. If you can get the treaded holes to line up with the 4 square holes in the center of the rim they should work. Weight is weight in my opinion. Yup, they don't have to be purdy, just purdy heavy !! 1 1 Share this post Link to post Share on other sites
oliver2-44 8,874 #5 Posted September 20, 2022 12 hours ago, Achto said: They look like brake drums filled with some thing. If you can get the treaded holes to line up with the 4 square holes in the center of the rim they should work. Weight is weight in my opinion. I've scratched around on them and their solid steel and yes I've got to check if the holes are the same spacing. 1 Share this post Link to post Share on other sites
