JR1
Wheel Horse year? Amd more! :)
JR1
Good day, folks. I have a 310-8... have had it for some time. I've been using it more since my Crapsman YT3000 croaked. Just picked up a snow plow frame and blade and need to dig into some pieces and parts for it. But I need a choke cable. Mine keeps seizing up. I'm trying to find out what year my WH is and have not been able to do so. I also need to track down a mule drive tension adjuster. The black plastic on mine has broken and its not fun trying to twist it. I'll probably grind the edges down a bit and tape it up for now. I'd like to grab any manuals for it that I can. The tag under the seat shows 2110K804 and 20559. Thank you! I appreciate your help!
Sparky
:WRS:
 21-10K804 1987 310-8 Garden Tractor 8 Speed Kohler M10S-461521
Pullstart
:text-welcomeconfetti:
SylvanLakeWH
Retired Wrencher
JR1:WRS: Enjoy the site. As you can see lots of help here.
953 nut
:WRS:
Lowell @wheelhorseman is a vendor here and has good quality products. Here is a link to the knob you need for the mule drive.  https://wheelhorsepartsandmore.com/product/101851-attach-o-matic-adjustment-knob-wheel-horse/ and your choke cable.  https://wheelhorsepartsandmore.com/product/8104-102118-toro-wheel-horse-choke-control-cable/
:wwp:
peter lena
@JR1  when replacing a  choke/ throttle cable , ROUTING  AND VERIFACATION OF FUNCTION  is most important , next is lubrication for that cable ,https://www.bing.com/images/search?view=detailV2&ccid=E5gt6z5s&id=FDFB409DB6F02336E8F3C66B73970F26637F5CCC&thid=OIP.E5gt6z5sFtf7zU312R0kiwHaE8& super lube oil available h / w stores , hang new cable vertically , drip in top edge , till it comes out bottom . when laying out cable , continue to verify smooth easy function , don,t just jam it in place , add cable tabes if you can , probably find a mule drive adjuster screw on this site , lubricate related movement points , simple stuff , pete
Edited by peter lena
wrong site
