Regulator Rectifier Kohler 15 amp large 101450 & small 109313 1.0.0
7 Screenshots
Regulator Rectifier 15 amp
101450 used 1978-1981
Kohler 237335, 2540322 and 4140306
435-084 Stens replacement available from Banta Saw in Canada. They will ship to Europe. Same as 435-083 which has no fins
Smaller unit with 2-wire leads - 15 amp - One AC lead from stator jumpered to the DC+ terminal
109313 used 1982-1984
1982 C-85 8-Speed model 01-08K803
1982 C-105 8-Speed model 01-10K803
1982 C-125 8-Speed model 01-12K803
1982 C-145 Automatic model 01-14KE03
1983 C- 85 8-Speed model 11-08K801
1983 C-105 8-Speed model 11-10K801
1983 C-125 8-Speed model 11-12K801
1983 C-145 Automatic model 01-14KE04
1984 C-105 8-Speed model 11-10K802
1984 C-125 8-Speed model 11-12K802
1984 C-145 Automatic model 11-14KE01
1984 C-165 8-Speed model 11-16K801
The 10 amp voltage regulators were supplied with the engine so are not in the tractor parts lists.
Suspect the 10 amp voltage regulator part number was 101405.
Tecumseh 610749
Kohler 234279 and 4140308
Stens replacement 435-086
You can use a 15 amp regulator to replace a 10 amp regulator but the terminal locations are different.
