Operator manual #245-246
16 pages 4.94MB
Dated 11/30/64
1 page 312KB
Short frame tractors
Tractor drive belt 6146 replaced by 8005 and both no longer available from Toro - (4L x 72" or 1/2" x 72")
Ignition switch 4988 (5/8"-32 threads) replaced by 7263 (9/16"-24 threads)
Big Block Kohler Napa # 25-7345 .41" wide x 35.3" long side angle 37 degrees Cross section HC41
3 pages 118.48KB
1965 model 875 - Uses the 5052 hydro transmission identified at Toro as 3100077
1965 serial numbers that have shown up for the 875
130994
131002
131097
131161
131249
131314
131686
131716
132052
132215
133019 - May be 138019
142227
142327
142666 - White instead of red
142729
142812
142881
143048
Starter/generator belt
Kohler 10, 12hp 235262
Wheel Horse 1593 (3L x 34.4") - nla (Gates replacement 6735 3/8" x 35" 38 degree)
7345 Gates .410" x 35.09" 36 degree
25-7345 Napa .410" x 35.09" 36 degree
3 pages 117.97KB
1965 model 1075 - Uses the 5052 hydro transmission identified at Toro as 3100077
1965 serial numbers that have shown up for the 1075
126828
130336
130829
143268
143408
