Operator manual #320
2 pages 239.74KB
Dated 1/17/67
Manual pto for 1" shaft
Clutch plate is bolted to the engine pulley 1965-1967 PT-7
Clutch plate assembly 6655 is 6" diameter
Fits 8hp models
Fits 10hp models 1045, 1055, 1075 and 1046 using K241S-46219a
PT-7 replaced by 8-3311 83311
1964 model 1045 using K241S-46219a - Requires 7363 2-1/2" engine pulley
1965 model 855 - Requires 7363 2-1/2" engine pulley
1965 model 875 - Requires 7362 3-1/2" engine pulley
1965 model 1055 using K241S-46219a - Requires 7363 2-1/2" engine pulley
1965 model 1075 using K241S-46219a - Requires 7362 3-1/2" engine pulley
1966 model 856 - Suspect this should be included and requires 7363 2-1/2" engine pulley
1966 model 876 - Suspect this should be included and requires 7362 3-1/2" engine pulley
1966 model 1046 - PT-6 for 1-1/8" crankshaft came as standard equipment as per PSB #338b but may be wrong or K241S-46219a is wrong? - Requires 7363 2-1/2" engine pulley?
1967 model 857 - Suspect this requires 7363 2-1/2" engine pulley
1967 model 867 - Suspect this requires 7363 2-1/2" engine pulley
1967 model 877 - Suspect this requires 7362 3-1/2" engine pulley
