IPL #A-7136
Service notes
20 pages 1.97MB
Includes PSB #038 #050 #058 #060 #069 #070 #080 #348 #394A #430
653 Wiring Color pdf
1 page 168KB
753 Wiring Color pdf
1 page 206KB
There was a model 703
Tractor drive belt for 633, 653 and 753 #9691 - 1/2" x 70"
Kohler Starter/Generator belt
Toggle ignition switch for 633 magneto ignition 3279
Keyed ignition switch with single terminal for 653 is 3656 magneto replaced by 6890 and nla. See PSB #069
Keyed ignition switch for 753 battery type 1747
3 pages 116.08KB
1963 model 633
1963 serial numbers that have shown up for the 633
62-18509
25933
26108 - Model a guess Now has 8hp engine
26210
26234 - Original thought to be a 653
26355
26898
27126
27137 - Model number a guess
27167 - Has K141T-29102A Serial 654682
27256
28649 - Model number a guess
28818
28878 - Has K141T-29136A Serial 681196
28954 - Model number a guess
29190 - Has K141T-29136A Serial 681560
29250
29309
29454
29515
29681 - Model number a guess
29693
29735
31602
32336
33332
35309 - Could be 653 or 753
35380
38003
38760
38894
3 pages 116.72KB
1963 model 653
1963 serial numbers that have shown up for the 653
62-23813
62-23886
62-24087
62-24186 - Model number a guess
62-24495 - Model and year a guess
62-25049
26234
26693
26798
32416 - Could be a 753
32417 - Could be a 753
32492 - Could be a 753
33212
35242 - Could be a 753
35309 - Could be a 753
35818
35819
36207
37240 - Model number a guess
37241
37349
38815
38885
39131
44370 - Could be a 753
3 pages 117.49KB
1963 model 753
1963 serial numbers that have shown up for the 753
62-02093 - Looks wrong
62-22031
62-22113
62-22415
62-22929 - Model and year a guess
62-23113
62-23128
62-23191
62-23207
62-23435
62-23481
62-23486
62-23573
62-23646 - Model and year a guess
62-23737 - Model and year a guess
62-23823
62-23884
62-23960
62-24027 - Model a guess
62-24063 - Model a guess
62-24085
62-24420 - Located in Australia
62-24434 - Located in Australia
62-24500
62-24526
62-24618
62-24661 - Model a guess
26293 - Model a guess
26456 - Model a guess
27029
27911
28007
29299 - Model a guess
2969x - Model a guess
30148
30204
30239
30285 - Added 02-17-2019
30341 - Added 06-06-2019
30394
30458
31624
31802
32416 - Could be a 653
32417 - Could be a 653
32492 - Could be a 653
35242 - Could be a 653
35309 - Could be a 653
32532
32536
32537
32599 - Located in France
32628 - Model 753 is a guess
32713 - Model 753 is a guess
32829
32970
35518
35663 - Model 753 is a guess
36477
38033
39750
44370 - Could be a 653
44594 - Model a guess
45681 - Found in France - Moved to Belgium
46567 - Model a guess
47889 - Model a guess
47957 - Thought to be a 753 but most likely a model 754
