  • Please Read
  • Chrishar
    • Active
    How do you get the shaft out of this tensioner pulley on a 1960 suburban 400
    User Feedback
    squonk
    Posted (edited)
    The center pin presses out. I just did one on my 551. @76c12091520h K & B horse parts sells new Heavy duty pullies that are excellent!
    Edited by squonk
    • Excellent 2
    Share this comment
    Link to comment
    peter lena
    Posted
     @Chrishar pulley failure is due to poor lube choice , always look for  bearings with WIDE GREASE SHIELDS , done every one of mine , lucas green 550  deg flash point , another thing , eliminate the deck belt bounce , thats incremental  lube failure , add a pulley on the back side of belt return , eliminate  rotational drag , also do the mule drive pulleys , my pto lever start up , is very smooth easy and quiett , no screaming clutch , what is that  telling you ? once you  try it , your a convert , pete
    Share this comment
    Link to comment
    oliver2-44
    Posted (edited)
    @Chrishar
    I've ground the rivets out with a Dremel. The bearing is available from a NAPA. I've reassembled them with  small socket head bolts.  Also, @WHX?? has a setup to replace the bearing and reassemble them with rivets for a complete factory look. I had him do a couple for me.
    Edited by oliver2-44
    Share this comment
    Link to comment
