Similar Content
By 87 416-8 horse
I’m looking for wheel horse tractors for sale or for parts in the Eastern Nebraska or western Iowa area. Preferably 8 speed manuals. Pm me or comment with what you have. The worst I could say is it’s out of my price or distance range. Edit: engine is not important, it’s going to get a big diesel swap.
Thanks,
John
By Rob R
So... I got cabin fever and against my best judgement, picked up from my brother a 520H Model # 4120OE02; Serial 1033076 (1991) that he got from a Friend who claim it ran but hasn't been used in years and was in dry storage. Included was a 48-inch triple blade mower in very good condition, total cost $250 ..... I figured that even if the tractor was no good the deck was worth the coinage....... and it had a good new battery....... So got it home fixed the one flat tire, replace the cooked fuse in the fuse holder. Cranked the engine over it cough a few times and then quit, was not getting fuel, replace the fuel line from the tank to the pump, pump not pumping, replace it with a B&S pump, cranked her over and she started right up ran and idled decent with no noticeable smoke. p.s. the hour meter is disconnected but you can tell she was run hard and put away wet but overall, in fair to good condition.
So without doing anything else time for a test drive. It moved forward and backwards took her out into the yard got about 50 feet and the motor started laboring to me was like the transmission was putting a heavy load on engine, I tried to shift into neutral, but it wouldn't let me do that and then the engine bogs down and shuts off. Wait like 10 seconds start her up again and the issue repeats.... In all my years I have never had anything close to this issue hence my call for help.
I did all the normal stuff trans fluid looks clean added some 10-40 weight to top her off, did not change the filter yet as I do not have one in stock. You can start the engine without engaging the transmission and it will run fine until the cows come home..... put it in gear forward or reverse and it will go an little ways and then the load condition occurs, the engine loads up and is dragged down into a stall.
Appreciate all your advice as this one has me stumped......
By Duramax7man7
Very Solid tractor! Starts right up and Runs and Cuts like a Champ!
ONLY 419hrs
FEATURES:
Newer Agro Tires on Rear & Solid Front Turf Tires.
Wheel Weights on rear.
Fully Swapped Forward Swept axle and Steering off of 520h.
New Tractor Supply Adjustable Seat.
Exhaust Fully Restored. (Sandblasted, Outgassed and 2000deg High Temp Satin Exhaust Paint Coated.)
I ran my 60" Deck on this tractor for over a year with no issues.
Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
Asking >>>>> $1,099 OBO <<<<<<<
(248) 943-8634 Text or Call. God Bless.
By Little Red Horse
I am selling a 1970 Wheel Horse Electro 12. It is in *working condition*.
It has AG tires and a mid-mount blade from wheel horse.
It also has a front mounted generator that currently doesnt put out power. It has been in the barn quite a while, so it may be a corroded connection, not sure. Although there's not too much that goes wrong with them.
The tractor has been a great one for me. The last 6ish 7ish years that I've had it where I lived it brought the gravel back up my driveway for me every time it rained. In the last few months, it would run for 20-30min then die.
I was moving at the time so just didn't have the time to look at it. And it seems I still don't. Where I am currently I don't have a place for it. I don't want it setting out and deteriorating. So here we are.
Please contact me by text or email.
Thanks for looking!
By ohiofarmer
i know that there is ebb and flow with market conditions, but I have been seeing bargain 520 and c-160 prices more common. I recently saw a c-160 like model on a place other than here that was close by, but i did not get a chance to see it as I was still on a medical tether getting care. i say c-i60 like model because it was a series of numbers like 4455 or somesuch .Tractor had the k series engine clearly a sixteen HP and came with a decent looking deck and pusher blade. i called my buddy Jay and told him for the $250 ask , he better hustle after it. i really do not know if he did.
I also have been seeing 520s and such lower than I can remember as well as the D series..My theory is that people experiencing paycheck to paycheck living are increasing in number.
You even are seeing a lot more older trucks like square bodies and especially big blocks than you did before. we used to see this a lot in new trucks when fuel prices hit records.
i am not claiming expert status on this, but it seems to be trending this way one county next to indiana and 90 miles North of the Ohio River.
Tell me what you are seeing out there and what you think.
Edit: Jay and I ran up to buy Bob Ellison's tractor in MI. Bob was very nice to deal with and included his "last seat" I got super lucky buying my first C-160 that did not start and another one shortly dropped in to keep it company. The tractor described above was listed for only two days and was gone
