meadowfield 2,545 #26 Posted February 28, 2017 Tidied up the front hubs and made covers for the stub axles over the weekend 8 Share this post Link to post Share on other sites
19richie66 16,989 #27 Posted March 1, 2017 Nice work Mark, as always! 1 Share this post Link to post Share on other sites
meadowfield 2,545 #28 Posted March 7, 2017 bit of work on the propshaft - a steering column shaft that's telescopic and just about the right scale (mower PTO shafts are rare here in the UK) I've turned the clamp off and added a flange. 9 Share this post Link to post Share on other sites
HorseHead1089 99 #29 Posted March 7, 2017 I enjoy all of your work, it's excellent! Currently making more finalized drawings of what I hope to be an awesome custom design. Hopfully I will be able experiment with my design my first year of college that has a plentiful amount of machining and fab equipment! 1 Share this post Link to post Share on other sites
meadowfield 2,545 #30 Posted March 7, 2017 24 minutes ago, HorseHead1089 said: I enjoy all of your work, it's excellent! Currently making more finalized drawings of what I hope to be an awesome custom design. Hopfully I will be able experiment with my design my first year of college that has a plentiful amount of machining and fab equipment! Thanks... hopefully it gets better, there's a 15 speed transmission to come hopefully that's powershift. Lets see see some some more pics of your work! Share this post Link to post Share on other sites
Sparky-(Admin) 19,660 #31 Posted March 8, 2017 That little Peerless gear box you posted a pic of a few weeks back doesn't strike me as being very rugged.....might be a weak point. Maybe? Mike..... Share this post Link to post Share on other sites
meadowfield 2,545 #32 Posted March 8, 2017 15 hours ago, Sparky said: That little Peerless gear box you posted a pic of a few weeks back doesn't strike me as being very rugged.....might be a weak point. Maybe? Mike..... agree, however the same gears/construction are in C4's front axle and I've not broken it yet after a few years of abuse... I think for the purpose I need it for, it might be adequate - if it breaks in early testing then it will be back to the drawing board!!! 1 Share this post Link to post Share on other sites
meadowfield 2,545 #33 Posted March 12, 2017 (edited) Finished the adapter and propshaft flanges today. Prop drive works well... Edited March 12, 2017 by meadowfield 4 Share this post Link to post Share on other sites
meadowfield 2,545 #34 Posted March 19, 2017 (edited) Balanced a few more parts on the bench. Need to get the drop box designed next. I've picked up an earlier 3 speed transmission and the brake shaft runs the opposite way and is 3 times slower. Might have to look for a later one. (12:1 ratio) Edited March 19, 2017 by meadowfield 4 Share this post Link to post Share on other sites
meadowfield 2,545 #35 Posted May 23, 2017 slow progress, managed to make the other end of the propshaft in an amongst all the other jobs! deliberating over whether to do the axle cradle and pivot next or start on choosing the rear end gearbox. The peerless 2300 is tempting, but I think reverse is broken I've enough gearboxes in pieces, so don't really need another!!!! 1 Share this post Link to post Share on other sites
19richie66 16,989 #36 Posted May 23, 2017 Simply in awe of it all. This will be another masterpiece 1 Share this post Link to post Share on other sites
meadowfield 2,545 #37 Posted September 5, 2017 slow progress, due to Ewans RJ rebuild and other jobs. I acquired another peerless 2300 tranny which seemed ok, but split just in case... found lots of metal, a seized brake shaft bearing, two mangled seals and half a shim! I guess thats where all the metal came from - odd thing is, there wasn't a shim missing!!!! So a PO obviously had it rebuilt badly. In pulling the hubs off, I noticed JMC in the castings, so I can now conclude it rear end is from a Jacobsen. Just one more seal to replace, then it's on with the hub adapters and transfer box 3 Share this post Link to post Share on other sites
meadowfield 2,545 #38 Posted September 28, 2017 Short update, transfer box almost in situ - a bit of tidying up to do. 5 Share this post Link to post Share on other sites
meadowfield 2,545 #39 Posted October 3, 2017 (edited) Back to the front axle, need to get a mount done before starting the chassis. a small piece of ply made the template and gave me a centre point for the pivot. Two pieces of steel tube were repurposed for the mount. a quick zap with the welder - that 1" hole was a pain to drill and how the cradle sites with a cat 3 pin for the pivot. Edited October 3, 2017 by meadowfield 5 Share this post Link to post Share on other sites
Duramax7man7 505 #40 Posted November 6, 2017 Well son of a gun. Just found this thread and this right Angle gear box is the idea I had. Got one coming this week. I have a tractor already in mind for the upgrade though. It will be getting a frame upgrade though to start the process. It will need it. Nice work so far. 1 Share this post Link to post Share on other sites
953 nut 52,046 #41 Posted November 6, 2017 4 hours ago, Mastiffman said: Well son of a gun. Just found this thread and this right Angle gear box is the idea I had. Got one coming this week. I have a tractor already in mind for the upgrade though. It will be getting a frame upgrade though to start the process. It will need it. Nice work so far. 2 Share this post Link to post Share on other sites
Duramax7man7 505 #42 Posted November 6, 2017 I will get them. Trying to finish my snow thrower restore at this point. 2 Share this post Link to post Share on other sites
