dwcphoto 7 #26 Posted March 31, 2012 Hi Mike, Thank you for thinking of me. I picked up one yesterday that should be fine. Back story is it came out of a 520 that was crushed in an accident, so has only a few hour on it. I'm sure you all will be hearing more from me as the project progresses! thank you, dwc Share this post Link to post Share on other sites
Phife 1 #27 Posted May 19, 2019 On 3/28/2012 at 9:41 PM, dennist said: Here is a Sunstrand-Equal axle lengths on both sides. What is this tube that goes through the tool box? I have a 68 charger 12 that is the same? Share this post Link to post Share on other sites
953 nut 51,682 #28 Posted May 19, 2019 15 minutes ago, Phife said: What is this tube that goes through the tool box? I have a 68 charger 12 that is the same? That tube is for a cable from the lift rock-shaft to the rear sleeve hitch/slot hitch to lift rear attached implants. Share this post Link to post Share on other sites
Phife 1 #29 Posted May 19, 2019 Just now, 953 nut said: That tube is for a cable from the lift rock-shaft to the rear sleeve hitch/slot hitch to lift rear attached implants. Thank you 1 Share this post Link to post Share on other sites
JaysHorse 287 #30 Posted June 7, 2019 My 518H has the 700. With a little luck I may be scoring an 1100 but there are about 1600hrs on it. Share this post Link to post Share on other sites
