Tractor 1971 Many models IPL.pdf
Illustrated parts lists #A-5279
16 files
100 pages 32.51MB
1971 800 Automatic model 1-0450 symbol 18A -[ Tractor drive belt 101142 - (HB x 79.87" or 5/8" x 79.87")]
1971 800 Special model 1-0150 symbol 18S - [Tractor drive belt 101137 - (A x 89.0" or 1/2" x 89")]
1971 All long frame tractors symbol 1LF
1971 Bronco 14 model 1-0420 symbol 14B including serial # 781701 - [Tractor drive belt # 7478 replaces # 4535 - (HB/5L x 84.22" or 5/8" x 84.22")]
1971 Bronco 14 model 1-0421 symbol 14B after serial # 781701 - [Tractor drive belt # 7478 replaces # 4535 - (HB/5L x 84.22" or 5/8" x 84.22")]
1971 Charger 12 model 1-0400 symbol 12C - [Tractor drive belt # 7478 replaces # 4535 - (HB/5L x 84.22" or 5/8" x 84.22")] - Uses breakerless magneto ignition
1971 Raider 10 model 1-0300 symbol 10R - [Tractor drive belt 78-7100 replaced by 7473 - (HB x 81.9" or 5/8" x 81.9")]
1971 Raider 12 model 1-0310 symbol 12R- [Tractor drive belt 78-7100 replaced by 7473 - (HB x 81.9" or 5/8" x 81.9")] - Uses breakerless magneto ignition
1971 GT-14 model 1-0500 symbol 1GT (There was also a 1-0501 in 1971) - [Tractor drive belt 8334 - (B x 84.8" or 5/8" x 84.8")]
It appears Toro has used the 1970 GT-14 parts list for the 1971 models. Comparing the 1970 IPL to this original ipl the following differences were found.
Item # 57 front axle pin and plate 2736
Item # 58 right spindle 8146 replaced by 101448
Item # 59 left spindle 8147
Item # 64 steering shaft and pinion 9647
Item # 67 steering sector 4880
Item # 131 grill 8383
Item # 190 bracket 8845
Item # 191 speed clip 3023
Item # 239 20 amp fuse 9435 replaced by 101639
Item # 257 nylon bushing 938007
Item # 301 tool pin 1813 replaced by 106634
1971 All Lawn Rangers symbol 1LR
1971 Ranger Recoil start model 2-0200 symbol 1LRR - [Tractor drive belt 8133 - (4L x 73.8" or 1/2" x 73.8")]
1971 Ranger Electric start model 2-0210 symbol 1LRE - [Tractor drive belt 8133 - (4L x 73.8" or 1/2" x 73.8")]
1971 Workhorse 800 model 1-0100 symbol 18W - [Tractor drive belt 78-7100 replaced by 7473 - (HB x 81.9" or 5/8" x 81.9")]
Does not include CG-7, CG-7R, CG-8 and R-26
5955 hydro pump gasket nla - 102759 gasket should work
