Jimmy66 47 #1 Posted September 11, 2022 I am looking to tow about 650 lbs Share this post Link to post Share on other sites
Pullstart 71,215 #2 Posted September 11, 2022 It all depends on the terrain. It’ll pull it. Can it stop it? Flat ground? Probably no problem. My commando 6 is essentially the same machine. It could use more front weight! 1 2 Share this post Link to post Share on other sites
ri702bill 12,988 #3 Posted September 11, 2022 5 hours ago, Pullstart said: It’ll pull it. Can it stop it? Therein lies the rub - can you safely move it and stop??? 1 Share this post Link to post Share on other sites
953 nut 69,162 #4 Posted September 11, 2022 6 hours ago, Jimmy66 said: I am looking to tow about 650 lbs I have towed a car on level ground with a 953, but there was a driver in the car and the brakes worked. 1 Share this post Link to post Share on other sites
Wild Bill in VA 1,596 #5 Posted September 11, 2022 (edited) OK let's go back to old math. Back in the early 1960's Wheel Horse had the Suburban series, which were the models 400, 550, 401, 551 and model 701, now with these models you could get a 4-wheeled wagon of which the loaded capacity was 1,000 pounds. Now I can imagine a scary ride with a Suburban 400 going downhill with a 1,000-pound payload. The 1961 Model 701 you could get a front-end loader as an attachment, now this type of attachment requires a few add on's such as rear wheel weights to counterbalance a load. Now factor in the weight of the loader assembly, weight of the operator, plus the load in the bucket and the net weight of the Model 701 now you're talking close to 1,500 pounds. So, 650 pounds is a piece of cake for a Wheel Horse. Wild Bill in Richmond VA Edited September 11, 2022 by Wild Bill in VA 1 3 Share this post Link to post Share on other sites
clueless 3,439 #6 Posted September 11, 2022 3 hours ago, Wild Bill in VA said: OK let's go back to old math. Back in the early 1960's Wheel Horse had the Suburban series, which were the models 400, 550, 401, 551 and model 701, now with these models you could get a 4-wheeled wagon of which the loaded capacity was 1,000 pounds. Now I can imagine a scary ride with a Suburban 400 going downhill with a 1,000-pound payload. The 1961 Model 701 you could get a front-end loader as an attachment, now this type of attachment requires a few add on's such as rear wheel weights to counterbalance a load. Now factor in the weight of the loader assembly, weight of the operator, plus the load in the bucket and the net weight of the Model 701 now you're talking close to 1,500 pounds. So, 650 pounds is a piece of cake for a Wheel Horse. Wild Bill in Richmond VA So WH had a 4 wheel wagon capable of a 1000 Lbs in 1960 and 61? Share this post Link to post Share on other sites
Wild Bill in VA 1,596 #7 Posted September 11, 2022 2 hours ago, clueless said: So WH had a 4 wheel wagon capable of a 1000 Lbs in 1960 and 61? The original UW-64 made by G & R Manufacturing in Rockford; IL made a stout little wagon that Wheel Horse sold, now the UW-643 and UW-641 had a pay load capacity of just 600 pounds. Wild Bill in Richmond VA Share this post Link to post Share on other sites
