Kevippolito 3 #1 Posted September 5, 2022 why isn’t power getting to my ignition terminal of my key, it’s a brand new key switch. when i turn the key the engine cranks over, but i have no power going to the coil? any help Share this post Link to post Share on other sites
wallfish 19,498 #2 Posted September 5, 2022 Does the new switch have an "I" terminal on it ? I would be for Ignition If it's designed for a magneto ignition it is grounding that terminal you have going to the coil. and would have a M on the terminal. The switch should have ID letters on the back next to the terminals 2 Share this post Link to post Share on other sites
squonk 45,805 #3 Posted September 5, 2022 What are you even working on? 1 Share this post Link to post Share on other sites
Kevippolito 3 #4 Posted September 5, 2022 (edited) 51 minutes ago, wallfish said: Does the new switch have an "I" terminal on it ? I would be for Ignition If it's designed for a magneto ignition it is grounding that terminal you have going to the coil. and would have a M on the terminal. The switch should have ID letters on the back next to the terminals oh man! it does have a M on it, i just thought M standed for motor! it’s the 5 pin key setup with the wiring harness, so i thought it would’ve worked, is there anything i can do to fix it or is the key junk? they key also has a ground terminal that i have running to ground. by the way the tractor is a 1973 no name 12 hp @wallfish Edited September 5, 2022 by Kevippolito Share this post Link to post Share on other sites
Kevippolito 3 #5 Posted September 5, 2022 26 minutes ago, squonk said: What are you even working on? 1973 no name 12 hp Share this post Link to post Share on other sites
squonk 45,805 #6 Posted September 5, 2022 54 minutes ago, Kevippolito said: oh man! it does have a M on it, i just thought M standed for motor! it’s the 5 pin key setup with the wiring harness, so i thought it would’ve worked, is there anything i can do to fix it or is the key junk? they key also has a ground terminal that i have running to ground. by the way the tractor is a 1973 no name 12 hp @wallfish Wrong switch. You need a battery ignition switch with an I on it. 2 Share this post Link to post Share on other sites
Kevippolito 3 #7 Posted September 5, 2022 (edited) 12 minutes ago, squonk said: Wrong switch. You need a battery ignition switch with an I on it. oh man okay! thankyou for the help Edited September 5, 2022 by Kevippolito Share this post Link to post Share on other sites
wallfish 19,498 #8 Posted September 5, 2022 (edited) 1 hour ago, Kevippolito said: oh man! it does have a M on it, i just thought M standed for motor! it’s the 5 pin key setup with the wiring harness, so i thought it would’ve worked, is there anything i can do to fix it or is the key junk? they key also has a ground terminal that i have running to ground. by the way the tractor is a 1973 no name 12 hp @wallfish You didn't hurt anything. Get a switch intended for battery ignition A- Accesories (lights and such) R-Regulator/rectifier I- Ignition (to the + side of the coil) B-Battery ( wire from the + hot side of the solenoid) S- Start (small post on the solenoid ) Had it been the other way around with battery ignition switch on a magneto engine with 12v supplied to a magneto coil -- it would let the magic smoke out of the coil. No harm on yours and a valuable lesson with something learned. (Switches are not all the same and different applications require different switches) Edited September 5, 2022 by wallfish 3 Share this post Link to post Share on other sites
953 nut 64,647 #9 Posted September 6, 2022 A 103-990 switch should get you back in business. This diagram may be helpful. Share this post Link to post Share on other sites
Kevippolito 3 #10 Posted September 6, 2022 11 hours ago, wallfish said: You didn't hurt anything. Get a switch intended for battery ignition A- Accesories (lights and such) R-Regulator/rectifier I- Ignition (to the + side of the coil) B-Battery ( wire from the + hot side of the solenoid) S- Start (small post on the solenoid ) Had it been the other way around with battery ignition switch on a magneto engine with 12v supplied to a magneto coil -- it would let the magic smoke out of the coil. No harm on yours and a valuable lesson with something learned. (Switches are not all the same and different applications require different switches) thannkyou! 1 Share this post Link to post Share on other sites
