Wild Bill in VA 1,596 #1 Posted September 4, 2022 A front mounted sprayer for a Wheel Horse made by the MacKissac Company that also made the Mighty Mac Shredder. Now I ain't sure but I believe ya' would need some pretty big rear wheel weights ifn's the tank is full! Wild Bill in Richmond VA 8 Share this post Link to post Share on other sites
ebinmaine 79,695 #2 Posted September 4, 2022 Looks like it hangs on a bracket similar if not identical to the chipper shredder setup. What's the gallon or size measurement? I know with my Mackissic chipper shredder on the C160 -8 it'll stay fine and run around as an unweighted tractor but rear traction is certainly a challenge. I run fluid filled tires and steel weighs to counterbalance. 2 Share this post Link to post Share on other sites
Row Cropper 63 #3 Posted September 9, 2022 Here's a short video of my semi-mounted homemade sprayer! 30 gal tank with 12 volt pump. This is the second generation of this sprayer, the original was carried completely on the tractor and the front just sorta floated till you got some of the weight off! Tricycle front makes this sprayer very maneuverable and handy to operate! IMG_1106.MOV 1 Share this post Link to post Share on other sites
