Dans 414-8 2 #1 Posted August 31, 2022 (edited) For some reason the new to me 414-8 DOES not have any fuel filter Did they have them off the factory set up Where is the best place to put one under hood or at the rear of the tank a metal one or plastic one ALSO while at LOWES they have those new sparkplugs in the green packaging. They have the wider Electron bottom instead of the usual type (where you set the gap at) I forget what company SO..... Stick with the champion or go for it or another know dependable plug you guys have found .. thanks again guys ....daniel aka dans414-8 Edited August 31, 2022 by Dans 414-8 Share this post Link to post Share on other sites
Snoopy11 5,720 #2 Posted August 31, 2022 (edited) It should have one up near the engine side under the hood. Where you personally put it shouldn't matter too much though... as long as you put it in in the correct direction for flow. I use both metal and plastic. I happen to like the plastic because I can see the fuel flowing through... Don Edited August 31, 2022 by Snoopy11 2 1 Share this post Link to post Share on other sites
Snoopy11 5,720 #3 Posted August 31, 2022 15 minutes ago, Dans 414-8 said: They have the wider Electron bottom instead of the usual type (where you set the gap at) I forget what company SO..... Stick with the champion or go for it or another know dependable plug you guys have found .. I think the spark plugs in the green package are E3... I would NOT recommend using those. Just buy a good o'le dependable champion. If you wanted to upgrade... I would recommend an autolite... but that is totally unnecessary in your case. Don 1 Share this post Link to post Share on other sites
ri702bill 10,067 #4 Posted August 31, 2022 The 414, being a cousin to my C81 probably has a strainer filter in the tank shut-off - and they DO plug up over time... 2 Share this post Link to post Share on other sites
Dans 414-8 2 #5 Posted August 31, 2022 2 hours ago, Snoopy11 said: I think the spark plugs in the green package are E3... I would NOT recommend using those. Just buy a good o'le dependable champion. If you wanted to upgrade... I would recommend an autolite... but that is totally unnecessary in your case. Don Forgot to mention or ask'.... I checked what I had its a champion H1OC was or is this the correct plug? thanks again ...daniel aka dans414-8 Share this post Link to post Share on other sites
