dkg520 531 #1 Posted August 29, 2022 My carburetor bowl has developed a pin hole. Does anyone have a extra bowl to sell? Will also purchase the entire carburetor for a 1967 1057 with a 10hp Kohler. The pictures may help. Thank you Share this post Link to post Share on other sites
ri702bill 12,519 #2 Posted August 29, 2022 You need to post your request in the "wanted" section of the classifieds so it will get the attention it deserves. Not sure on the Walbro carbs, but there was a post a while back about using a Briggs steel bowl on the Carter model N carbs - direct replacement. Your pin holes are more than likely caused by those lovely Ethanol :"Pearls" - trapped water in the bottom of the bowl... 2 Share this post Link to post Share on other sites
dkg520 531 #3 Posted August 29, 2022 I will gladly move it to the wanted section as soon as I figure out how to. Thanks Share this post Link to post Share on other sites
ri702bill 12,519 #4 Posted August 29, 2022 or.... ask one of the Moderators / Admins to do so for you... Share this post Link to post Share on other sites
squonk 47,427 #5 Posted August 29, 2022 (edited) Briggs & Stratton 221995 is a direct replacement Edited August 29, 2022 by squonk 2 2 Share this post Link to post Share on other sites
Jeff-C175 7,209 #6 Posted August 29, 2022 Can't ya solder it up? If you've got nothing to lose, it's worth a try. 1 Share this post Link to post Share on other sites
dkg520 531 #7 Posted August 29, 2022 Thank you Squonk Share this post Link to post Share on other sites
squonk 47,427 #8 Posted August 29, 2022 31 minutes ago, dkg520 said: Thank you Squonk Actually I goofed. That bowl will not fit. It only fits Carter carbs. Sorry 1 Share this post Link to post Share on other sites
953 nut 67,503 #9 Posted August 29, 2022 5 hours ago, Jeff-C175 said: Can't ya solder it up? If you've got nothing to lose, it's worth a try. Soldering aluminum is not like soldering copper, special products and grater heat. 1 Share this post Link to post Share on other sites
Jeff-C175 7,209 #10 Posted August 30, 2022 49 minutes ago, 953 nut said: Soldering aluminum is not like soldering copper, special products and grater heat. I guess it is aluminum... I thought it was steel. Share this post Link to post Share on other sites
wallfish 20,231 #11 Posted August 30, 2022 This stuff works great for pin hole type stuff and stands up to the fuel. 2 Share this post Link to post Share on other sites
