Hampton 95 #1 Posted August 29, 2022 I was looking at the chart for my horse and noticed it says the clevis hitch is for non ground engaging implements. If so, what should I use for a middle buster plow? What is a PAL implement? Thanks Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,875 #2 Posted August 29, 2022 I have forgotten what PAL stands for. Wheel Horse determined what other manufacturers' equipment could be used on the tractors and made a Permitted Attachment List is just a guess. If you go back and check the non-ground engaging attachments may be for the lighter 200-Series tractors. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,875 #3 Posted August 29, 2022 I see it now in the 1992-93 model years but not there for 1985-86 Share this post Link to post Share on other sites
Hampton 95 #4 Posted August 29, 2022 1 hour ago, gwest_ca said: I see it now in the 1992-93 model years but not there for 1985-86 I'm not 100% percent sure,but I was going under 1990. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,875 #5 Posted August 30, 2022 Perhaps the limiting factor was the 4-pinion differential and 1" axles. Share this post Link to post Share on other sites
kpinnc 16,334 #6 Posted August 31, 2022 The transmission on a 310-8 should handle most anything you pull behind it. While lighter duty than the 1.125 axles and 8 pinion diff, it's still as rugged as every 3 speed 1960 model and after that came before it. I've used a Brinly moldboard plow behind mine in hard red clay as well as a cultivator. The wheels will spin before you break anything in most cases, unless you have a crazy amount of weights on the tractor. With a middle buster, it's all about leverage. If the ground is unbroken, it's hard on any machine. How deep you run it is where you can get into trouble. I wouldn't think you'd break anything unless you try to go max depth in high gear with alot of rocks in the soil. Share this post Link to post Share on other sites
