kpinnc 16,230 #76 Posted March 5, 2023 On 2/24/2023 at 4:23 PM, Wild Bill 633 said: The tachometer and oil pressure gauge have been mounted in the hood stand. Looks very nice! What does the tach get the RPMs from? 1 Share this post Link to post Share on other sites
Wild Bill 633 899 #77 Posted March 5, 2023 1 hour ago, kpinnc said: What does the tach get the RPMs from? I have been told I can get the tach pickup from the negative side of the ignition coil or wrap a wire around the spark plug wire. 2 Share this post Link to post Share on other sites
Pullstart 68,534 #78 Posted March 6, 2023 I have no answer to my question, but generally great plug wires block interference from external sources, right? Would wrapping a winding around it alter the final power? Share this post Link to post Share on other sites
Wild Bill 633 899 #79 Posted March 7, 2023 14 hours ago, Pullstart said: Would wrapping a winding around it alter the final power? I do not think so. I called Design Technology, Inc. the makers of the Tiny Tach and talked to their electrical engineer. The Tiny Tach has a wire that wraps around a spark plug wire for inductive pick up of the spark plug pulse to trigger the tach. 1 2 1 Share this post Link to post Share on other sites
Oldskool 6,666 #80 Posted March 9, 2023 So basically it works on the same idea as an automotive timing light? Ive seen those little tachs but just wasn't sure if they were worth the purchase. 2 Share this post Link to post Share on other sites
Blasterdad 3,104 #81 Posted March 9, 2023 You can get hour meters with a plug wire pickup too... Share this post Link to post Share on other sites
Wild Bill 633 899 #82 Posted March 24, 2023 (edited) Since my last post, the crankshaft has been balanced, and engine assembly has started. Installed crankshaft, rods and pistons, roller camshaft degreed, roller lifters and cylinder heads. Next, determine the correct push rod length. Edited March 24, 2023 by Wild Bill 633 2 2 Share this post Link to post Share on other sites
Wheelhorse#1 1,890 #84 Posted March 25, 2023 Great looking machine and fabrication work, Bill.You really thought this out. Will it be at the big show this yr ? Share this post Link to post Share on other sites
Wild Bill 633 899 #85 Posted March 25, 2023 (edited) 8 hours ago, Wheelhorse#1 said: Great looking machine and fabrication work, Bill.You really thought this out. Will it be at the big show this yr ? I do not think It will be finished. I am waiting for the carburetor which is at an engine builder to replace the OEM emulsion tube with a jet and adjuster. Then the engine will be run to determine the idle speed so the CVT can be ordered. Some other things to be completed are brake master cylinder, jackshaft, v-belt tensioner, plumbing and electrical. Test run and debug. Then to sheet metal shop and then disassembly for paint. I have been working on this project for 20 months and the one thing this project has taught me is there is always light at the end of the tunnel and patience. Hopefully next year we will see all of you. Can't wait. Edited March 25, 2023 by Wild Bill 633 5 Share this post Link to post Share on other sites
Wild Bill 633 899 #86 Posted March 29, 2023 Correct push rod length has been determined. After 10 months, it's time to finally assemble the engine. 1 3 Share this post Link to post Share on other sites
Wild Bill 633 899 #87 Posted March 29, 2023 Started to assemble the engine today. Still waiting for carb. 1 4 Share this post Link to post Share on other sites
Wild Bill 633 899 #89 Posted March 29, 2023 (edited) Edited March 29, 2023 by Wild Bill 633 1 3 1 Share this post Link to post Share on other sites
Pullstart 68,534 #91 Posted March 29, 2023 Nice square body Chevy! Share this post Link to post Share on other sites
WHX?? 53,372 #92 Posted March 30, 2023 Ahhh let's keep our eyes on the bikini shant we Kev? 1 4 Share this post Link to post Share on other sites
Pullstart 68,534 #93 Posted March 30, 2023 1 minute ago, WHX?? said: Ahhh let's keep our eyes on the bikini shant we Kev? I thought I was!?!?!? Share this post Link to post Share on other sites
WHX?? 53,372 #94 Posted March 30, 2023 (edited) Ahhh.... no... that's a beach ball... Does a square body have a front end like that? ... well maybe some do... Ignore our bantering Bill... carry on... Edited March 30, 2023 by WHX?? Share this post Link to post Share on other sites
Wild Bill 633 899 #95 Posted March 30, 2023 23 minutes ago, Pullstart said: Nice square body Chevy! 1986 GMC K2500 HD 3/4 ton 4X4 350CI 4-Speed which I bought new. The last year of the carburetor and less than 200 HP. So replace the top end with roller-hydraulic camshaft, Brodix Track 1 cylinder heads, roller rockers, stud gridle, Edelbrock Air Gap intake and throttle body fuel injection. Started this project and I got distracted with my Wheel Horse Hot Rod project by @Achto. After the Hot Rod project is done I need to complete this project. 3 5 1 Share this post Link to post Share on other sites
WHX?? 53,372 #96 Posted March 30, 2023 Oh sure Bill... that helps ... here we was trying to get him back on the wagon... 2 Share this post Link to post Share on other sites
Tractorhead 9,215 #97 Posted March 30, 2023 6 hours ago, Wild Bill 633 said: 1986 GMC K2500 HD 3/4 ton 4X4 350CI 4-Speed which I bought new. The last year of the carburetor and less than 200 HP. So replace the top end with roller-hydraulic camshaft, Brodix Track 1 cylinder heads, roller rockers, stud gridle, Edelbrock Air Gap intake and throttle body fuel injection. Started this project and I got distracted with my Wheel Horse Hot Rod project by @Achto. After the Hot Rod project is done I need to complete this project. Nice, i love it. 1 Share this post Link to post Share on other sites
Pullstart 68,534 #98 Posted April 13, 2023 @Wild Bill 633 asked me to post these 7 Share this post Link to post Share on other sites
Pullstart 68,534 #99 Posted April 13, 2023 I’d say it sounds awesome! 9 Share this post Link to post Share on other sites
ebinmaine 75,822 #100 Posted April 13, 2023 NIIIIICE 👍👍👍👍 Share this post Link to post Share on other sites
