DeepH2O 66 #1 Posted August 25, 2022 I’m replacing bearings and seal on the PTO bell housing. Up until this point, before taking ANYTHING apart, I’ve been taking numerous pictures so I can use for reference. Well, I took some of bearing placement before removal, but not enough. It may be ok. The picture of old needle bearing and seal looks like there’s a small gap between bearing and seal (I should’ve measured, I measured the other bearing depth before removal). Well, after getting new bearing in, I installed seal. The gap looks the same as prior to removing old one. But, after flipping over to install other bearing, I noticed a “lip” inside that I’m wondering if I should’ve “drove” bearing into. But, the gap between needle bearing and seal would be greater than before. If the old bearing was in correct, it wasn’t seated on the lip, I don’t think. Can someone verify if this bearing is on correctly or if it needs to “seated” on this lip? I should’ve taken my time before removing!! Thanks! 1 Share this post Link to post Share on other sites
Jeff-C175 7,207 #2 Posted August 25, 2022 Last one I did I seated it against the land, but I don't think it will be a problem. I hope you pressed that in and not drove it in? Share this post Link to post Share on other sites
johnnymag3 2,634 #3 Posted August 25, 2022 15 minutes ago, Jeff-C175 said: Last one I did I seated it against the land, but I don't think it will be a problem. I hope you pressed that in and not drove it in? Agree with Jeff....you should be ok.....Also see the post for Grease. I have seen them on the land and everywhere in between. Never beat a bearing in.....you did press it right? John Share this post Link to post Share on other sites
DeepH2O 66 #4 Posted August 26, 2022 Yes, I pressed it in. Which post are you referring to about the grease? Share this post Link to post Share on other sites
DeepH2O 66 #5 Posted August 26, 2022 I would think you would want it seated as well, it just threw me off by not being seated when it came off. I don’t recall my dad ever changing those bearings, but may have. I’d give $1 million just to be able to ask him!! 2 Share this post Link to post Share on other sites
peter lena 9,761 #6 Posted August 26, 2022 @DeepH2O https://www.autozone.com/greases-and-gear-oil/lubricant-grease/p/lucas-oil-products-xtra-hd-grease-tube- this is the grease to use , no screwing around , 560 deg heat rated , minimum grease coverage , to avoid clutch face spray . have also removed my related break pad set up on the cone , that cone will just spin without effort ,and no noise , failure , been testing mine for years . also use this grease in all my deck and mule drive bearings , clean out and repack new bearings , greasy , pete Share this post Link to post Share on other sites
DeepH2O 66 #7 Posted August 26, 2022 27 minutes ago, peter lena said: @DeepH2O https://www.autozone.com/greases-and-gear-oil/lubricant-grease/p/lucas-oil-products-xtra-hd-grease-tube- this is the grease to use , no screwing around , 560 deg heat rated , minimum grease coverage , to avoid clutch face spray . have also removed my related break pad set up on the cone , that cone will just spin without effort ,and no noise , failure , been testing mine for years . also use this grease in all my deck and mule drive bearings , clean out and repack new bearings , greasy , pete Awesome!!! Thanks Pete! 1 Share this post Link to post Share on other sites
Jeff-C175 7,207 #8 Posted August 26, 2022 2 hours ago, peter lena said: grease And don't use 'too much' grease in that housing. You don't want it oozing out past the bearing on the outside, or the seal on the inside. 2 Share this post Link to post Share on other sites
Wheelhorse#1 1,901 #9 Posted August 26, 2022 I used a big C-Clamp and a thick piece of copper to press mine in.Was a tight fit for sure. Yours looks good 1 Share this post Link to post Share on other sites
DeepH2O 66 #10 Posted August 27, 2022 7 hours ago, Wheelhorse#1 said: I used a big C-Clamp and a thick piece of copper to press mine in.Was a tight fit for sure. Yours looks good I’ve got a really strong wood vise that usually does the trick. 1 Share this post Link to post Share on other sites
