peter lena 9,505 #51 Posted August 7, 2023 @John2189 never use water on it , once you get oil; into the paint finish , thats your , patina , thats your cleaner , thats your paint finish ! been doing this for years , like KROIL to wake up paint , let it soak in a day , wipe down , with clean soft cloth , soak it down again , I also use a cleaner wax with a 6" electric palm buffer . to pull out the shine . then all you do is regularly rub it down to make it shine , you want oil in the finish , not water , pete 1 Share this post Link to post Share on other sites
WHX?? 53,081 #52 Posted August 7, 2023 1 hour ago, rjg854 said: You just retired and you're losing it already. I'll plead the fifth Randy but in my defense I just came off a eight day show run with @Achto ☠️ 🏴☠️... 5 minutes ago, Rob J. said: Fleabay actually. A repop but cheap. Like $35. Saw those Rob ...thanks 2 2 Share this post Link to post Share on other sites
John2189 557 #53 Posted August 8, 2023 47 minutes ago, peter lena said: @John2189 never use water on it , once you get oil; into the paint finish , thats your , patina , thats your cleaner , thats your paint finish ! been doing this for years , like KROIL to wake up paint , let it soak in a day , wipe down , with clean soft cloth , soak it down again , I also use a cleaner wax with a 6" electric palm buffer . to pull out the shine . then all you do is regularly rub it down to make it shine , you want oil in the finish , not water , pete Thanks Peter 2 Share this post Link to post Share on other sites
