mike avad 49 #1 Posted August 24, 2022 I have a 1965 875 wheel horse and I had this tractor gave to me I'V redone it and I also have 2 gang's mowers and am missing one. and am trying to fine the part's to be able to hook them up to this tractor.am knew at this and this is my first tractor IV redone. 2 of the gang's mower go in the middel of the tractor and one go's in the back.I have a booklet that show a photo of the gang's mower on my 1965 875 wheel horse. and IV look up and down for any info on this so at this point am LOST? any info would be helpful thanks for any replys on this. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,753 #2 Posted August 24, 2022 1 1 Share this post Link to post Share on other sites
peter lena 9,471 #3 Posted August 24, 2022 @mike avad suggestion , what ever you set up / intend to use , take the time to verify its movability , if you can individually , look over ground to frame movement spots for verified lubrication and ease of function , that would be a good start , chances are you will be hooking on to a weighted sled for intended use. aerosol lubricant first , make rust run out , then red grease aerosol , to stay with it . the easier it moves the easier it functions , just basic stuff , pete Share this post Link to post Share on other sites
ri702bill 10,088 #4 Posted August 24, 2022 9 hours ago, gwest_ca said: Perfect for keeping the Gopher and ferral cat populations in check !! 1 Share this post Link to post Share on other sites
