Alex175 785 #1 Posted August 23, 2022 So it looks like my C-195 needs a new battery, it started with the occasional jump, or needing to be charged, and now I'm getting nothing, won't take a charge and won't start without a jump....so it's time. The question is, what is the right battery for me? With the bigger motor I typically go for the high end on the CCA, ~300+ but I am also looking at the fact that I have been setting this machine up to run special attachments, such as a winch, and possibly a small salt spreader for the winter. Do they make a deep cycle small engine battery? Should I go with an AGM over a traditional lead acid? Is there a way to sneak something bigger in there? Are all of these thoughts a moot point because the recharge system on the tractor will not enough to offset the power usage? Any ideas, or experience is greatly appreciated. Share this post Link to post Share on other sites
rmaynard 17,583 #2 Posted August 23, 2022 Sticking with my tradition of keeping things as close to original as possible, I'd put in a lead acid 340 CCA regular old battery. 5 Share this post Link to post Share on other sites
rmaynard 17,583 #3 Posted August 23, 2022 (edited) However, if your current battery has the ability, remove the caps to check the water level. I'd do that first, then put a 10 to 15 amp charger on it for 24 hours. If it still doesn't hold a charge, replace it. Edited August 24, 2022 by rmaynard punctuation 2 Share this post Link to post Share on other sites
953 nut 69,479 #4 Posted August 23, 2022 I have found that a 200 CCA battery will give me a couple years of service and a 360 CCA battery will give me four or more years of service. For the most part they all come out of the same factory so I have no brand loyalty, just shop around for the best price. The electrical loads like a winch will be powered by your charging system while the engine is running. 2 Share this post Link to post Share on other sites
WHX?? 58,194 #5 Posted August 24, 2022 I think I just have a 230 CCA I n my Super C and it does just fine. Strictly summer seasonal tho. I'm like Richard and have no brand loyalty when it comes to 10 + tractors to keep batts in. If yer gonna use it in the winter go with something the better side of 300 and keep it on a tender. I have good luck with my 520s doing this. Guessing engine charging circuits are OK? 1 Share this post Link to post Share on other sites
Alex175 785 #6 Posted August 24, 2022 11 hours ago, 953 nut said: For the most part they all come out of the same factory so I have no brand loyalty Yeah from my knowledge of the battery industry I believe there are only 3 primary manufacturers in the US and that most of what we see out there are private labeled batteries from these same manufacturers 11 hours ago, WHX?? said: Guessing engine charging circuits are OK? I think they probably are, though I should check that with my load tester. The battery that is in it is the same battery that it came with when it made its trek east to my stables in 2019 and I have only had minor issues with it until recently. The other weird thing with this tractor specifically as opposed to all of my other ones is this is the only one that builds corrosion on the terminals, and even on the battery hold down bracket. All my other WH have never had this issue, but this machine can build up a whole mass of battery corrosion crust pretty quick. I always assumed it was because it is the style that you can open, where I normally have a sealed battery, so I assumed that it had to do with gasses escaping while in operation or charging. 1 Share this post Link to post Share on other sites
953 nut 69,479 #7 Posted August 24, 2022 1 hour ago, Alex175 said: I always assumed it was because it is the style that you can open, where I normally have a sealed battery, so I assumed that it had to do with gasses escaping while in operation or charging. 1 1 Share this post Link to post Share on other sites
pfrederi 21,172 #8 Posted August 24, 2022 If you want a really good long lasting battery go big. Older WHs had a larger battery tray that will accept a 22NF or GRP 52 battery. The tractors came with automotive batteries, top terminal posts. They are a lot more money but I have had very good luck with the two I run with them.... 1 Share this post Link to post Share on other sites
lynnmor 9,042 #9 Posted August 24, 2022 2 hours ago, Alex175 said: Yeah from my knowledge of the battery industry I believe there are only 3 primary manufacturers in the US and that most of what we see out there are private labeled batteries from these same manufacturers I think they probably are, though I should check that with my load tester. The battery that is in it is the same battery that it came with when it made its trek east to my stables in 2019 and I have only had minor issues with it until recently. The other weird thing with this tractor specifically as opposed to all of my other ones is this is the only one that builds corrosion on the terminals, and even on the battery hold down bracket. All my other WH have never had this issue, but this machine can build up a whole mass of battery corrosion crust pretty quick. I always assumed it was because it is the style that you can open, where I normally have a sealed battery, so I assumed that it had to do with gasses escaping while in operation or charging. I would carefully check the voltage, out gassing is often caused by over charging. 1 Share this post Link to post Share on other sites
WHX?? 58,194 #11 Posted August 24, 2022 (edited) 3 hours ago, Alex175 said: Yeah from my knowledge of the battery industry I believe there are only 3 primary manufacturers in the US and that most of what we see out there are private labeled batteries from these same manufacturers I think they probably are, though I should check that with my load The other weird thing with this tractor specifically as opposed to all of my other ones is this is the only one that builds corrosion on the terminals Funny you should mention that Alex. My 195 does the same thing with a sealed one and the only horse I have that does it. Yes older long frames like my 1067 & 1077 take the older round post batts like a Paul mentioned. 85 clam batteries but 10 years out of them. Unfortunately nowhere to shoehorn them in on shorts or a C. Edited August 24, 2022 by WHX?? 1 Share this post Link to post Share on other sites
peter lena 10,076 #12 Posted August 24, 2022 (edited) Edited August 24, 2022 by peter lena duplication of reply Share this post Link to post Share on other sites
peter lena 10,076 #13 Posted August 24, 2022 @Alex175 last photo , showing battery tender plug in and additional ground cable to engine frame area , pto lever start washers , pete 1 Share this post Link to post Share on other sites
