zach-olivia 1 #1 Posted August 23, 2022 Will a charger 10 engine go in a c101 without modifications Share this post Link to post Share on other sites
ebinmaine 74,575 #2 Posted August 23, 2022 Does the Charger 10 currently have a Kohler or Tecumseh engine? Share this post Link to post Share on other sites
ebinmaine 74,575 #4 Posted August 23, 2022 13 minutes ago, zach-olivia said: Kohler If the ignition system is the same in both tractors it would be a direct swap. If they both have points, you're all set. Otherwise you may have to swap ignition switches and change the wiring a little... which is probably not that big of a deal. 2 Share this post Link to post Share on other sites
Blasterdad 3,044 #6 Posted August 23, 2022 (edited) A C-101 has a Shaker Plate Mount, A Charger 10 motor should be a long block. You should be able to remove the Shaker Mount & bolt the long block directly to the frame. You will have to use a different bracket for the lower PTO arm mount, it bolts on top of the Tach-A-Matic bracket. Edited August 23, 2022 by Blasterdad 1 Share this post Link to post Share on other sites
zach-olivia 1 #7 Posted August 23, 2022 Thank you for the info. Share this post Link to post Share on other sites
953 nut 62,181 #8 Posted August 23, 2022 Unless the engine has been changed to battery ignition already your engine has the trigger ignition system and the C-101 could be magneto or battery ignition depending on the model number. Please post the ignition type and model number of the C-101 and the ignition system type in your Charger. If changes need to be made we can walk you through it. 1 Share this post Link to post Share on other sites
