Hampton 95 #1 Posted August 23, 2022 Looking through market place and seeing a few with a few hours drive, some with extra gears and some not. Curious about what I should be looking for exactly. Hate to buy one and then realize I still need more parts. Share this post Link to post Share on other sites
squonk 47,887 #2 Posted August 23, 2022 You need the rear axle bracket ,cable and rear rockshaft to lift it idler pulley and bracket and a long honkin belt! Share this post Link to post Share on other sites
Hampton 95 #3 Posted August 23, 2022 I have the clevis hitch and rock shaft to install. The long honkin' belt is on order because it's the same one I need for my mower deck. Appears to be the idler pully, shaft and spring i need. Share this post Link to post Share on other sites
c-series don 12,362 #4 Posted August 23, 2022 The tiller belt and the mower belts are not the same. 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,451 #5 Posted August 23, 2022 This is the tiller used in 1985 for the 310-8. The parts list shows all the necessary pieces. Later tillers will also fit. Earlier ones will work with modifications. 1986-1989 tiller model 07-36TL03 Uses tiller hitch 105543 Rear axle hitch mounts under rear axle [Drive belt # 1599 (HA x 139.00in 1/2" x 139") If used on later twin-cylinder models use belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1990-1991 tiller model 07-36TL04 Uses tiller hitch 105543 Rear axle hitch mounts under rear axle [Drive belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1992 tiller model 07-36TL05 Uses tiller hitch 105543 Rear axle hitch mounts under rear axle [Drive belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1993-2001 2003-2007 tiller model 79370 Rear axle hitch mounts under rear axle [Drive belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1 1 Share this post Link to post Share on other sites
Hampton 95 #6 Posted August 23, 2022 My mower is the 37" I believe which uses the same 110265 belt. However, I may only have a one cylinder so I'll have to check. Still so new to this. Share this post Link to post Share on other sites
Hampton 95 #7 Posted August 23, 2022 (edited) 2 hours ago, c-series don said: The tiller belt and the mower belts are not the same. Yes and no I think. Mower deck belt for 37" is 110265. It's the same belt for the tiller if I have a twin cylinder motor which i probably don't have with just 10hp. Edited August 23, 2022 by Hampton Share this post Link to post Share on other sites
