dirtywheel 0 #1 Posted July 11, 2009 picked up another horse today model number 1-3745...according to the toro site it is a wheelhorse 700........,but my decals are different and it has a 7 hp pullstart kohler...everything looks original and correct,or is the toro site incoorect?? link to the horse i brought home http://rockford.craigslist.org/grd/1262638959.html Share this post Link to post Share on other sites
Buzz 502 #2 Posted July 11, 2009 Hmmm...... interesting. I take it that you have the tractor and have verified that it is a Kohler and that 1-3745 is the model number on the tractor. According to Toro, and they've been wrong before, the only 7hp Kohler with a recoil start was the 1976 B-60, model numbers 61-07K801 and 61-07K802. If you look in the picture gallery in this forum there are pictures of both the 1969 Workhorse 700 and the 1976 B-60 and neither really look like your new tractor. Does anyone recognize what model had those hood decals? Try posting all of the engine numbers and maybe we can figure out what tractor that engine should be on....... :thumbs: Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #3 Posted July 11, 2009 The hood decals are 1970-72 and are not original to that tractor. There's no doubt that the original Tecumseh died and was replaced by the Kohler. If the engine looks to be Wheel Horse red it could be off of a 704, 706, (highly unlikely) or a B-60 but could also be off of a Troy-Bilt tiller. (similar color) As Buzz has stated, the numbers will be a great help. I'm betting that with closer inspection you'd find this tractor has had more than a few alterations - both cosmetic and mechanical. Share this post Link to post Share on other sites
Michael Bullington 5 #4 Posted July 11, 2009 Looks just like a workhorse 700 with an engine swap,,,And added hood decals! Nice find! :thumbs2: Share this post Link to post Share on other sites
dirtywheel 0 #5 Posted July 11, 2009 OK...here is some new info !!! Kohler model number k161T spec# 281271J ser# 9584011 motor block red.....cover purpleish red.....recoil red the block has to broken bolts left in it where the gen/starter bracket once was Came back from the lake county indiana steam show today..pics later, but had a 700 there and all was same including deck, but the motor and decals....so my guess is just that also...... Share this post Link to post Share on other sites
linen beige 16 #6 Posted July 12, 2009 According to Kohler that spec # was built for a Gardenway (Troy-Bilt) tiller. The model # of K161T was originally a retractable (recoil) start. That's what the "T" stands for. It is possible that someone mounted a starter/gen on it at some point but the ignition would have to be switched and then switched back to make it a recoil start again.. I think it's pretty unlikely anyone would do that. The broken bolts in the block were more than likely from something used with the original tiller set up. Share this post Link to post Share on other sites
