dirtywheel
another horse in the garage
dirtywheel
picked up another horse today model number 1-3745...according to the toro site it is a wheelhorse 700........,but my decals are different and it has a 7 hp pullstart kohler...everything looks original and correct,or is the toro site incoorect??
link to the horse i brought home
http://rockford.craigslist.org/grd/1262638959.html
Buzz
Hmmm...... interesting. I take it that you have the tractor and have verified that it is a Kohler and that 1-3745 is the model number on the tractor. According to Toro, and they've been wrong before, the only 7hp Kohler with a recoil start was the 1976 B-60, model numbers 61-07K801 and 61-07K802. If you look in the picture gallery in this forum there are pictures of both the 1969 Workhorse 700 and the 1976 B-60 and neither really look like your new tractor. :thumbs2: Does anyone recognize what model had those hood decals? Try posting all of the engine numbers and maybe we can figure out what tractor that engine should be on....... :thumbs:
TT
The hood decals are 1970-72 and are not original to that tractor. There's no doubt that the original Tecumseh died and was replaced by the Kohler. :thumbs2: If the engine looks to be Wheel Horse red it could be off of a 704, 706, (highly unlikely) or a B-60 but could also be off of a Troy-Bilt tiller. (similar color) As Buzz has stated, the numbers will be a great help.
I'm betting that with closer inspection you'd find this tractor has had more than a few alterations - both cosmetic and mechanical.
Michael Bullington
Looks just like a workhorse 700 with an engine swap,,,And added hood decals!
Nice find! :thumbs2:
dirtywheel
OK...here is some new info !!!
Kohler
model number k161T
spec# 281271J
ser# 9584011
motor block red.....cover purpleish red.....recoil red
the block has to broken bolts left in it where the gen/starter bracket once was
Came back from the lake county indiana steam show today..pics later, but had a 700 there and all was same including deck, but the motor and decals....so my guess is just that also......
linen beige
According to Kohler that spec # was built for a Gardenway (Troy-Bilt) tiller.
The model # of K161T was originally a retractable (recoil) start. That's what the "T" stands for. It is possible that someone mounted a starter/gen on it at some point but the ignition would have to be switched and then switched back to make it a recoil start again.. I think it's pretty unlikely anyone would do that. The broken bolts in the block were more than likely from something used with the original tiller set up.
