Schlarf1033 0 #1 Posted August 21, 2022 In the process of rebuilding my 6-6212 snowblower. Surprising everything came apart easily, including the auger shaft. I'm wanting to replace all bearing and sprockets. Looking for any information on locating parts. Thanks in advance. Dale. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,015 #2 Posted August 22, 2022 Share this post Link to post Share on other sites
peter lena 9,782 #3 Posted August 22, 2022 @Schlarf1033https://www.walmart.com/ip/Snow-Sled-Lightweight-Roll-Up-Snow-Sled-Portable-Rolling-Snow-Slider-for-Adults-Flexible-Flat/789262266? using this or similar to make a slide gasket under the blower chute area , very easy , place chute on material , magic marker a size to size casket , use SUPER LUBE , aerosol; or small bottle lubricant , effortless swing . also change over to , bolt on electrical lug ,https://www.lowes.com/pd/Southwire-Lug-Al-2-14-STD-2-PK/5001719571?cm_mmc=shp-_-c-_-prd-_-, on sides of chute swing pull point , drill out original , bolt this on , detail your build up / lubrication , also detail your drive belt 2 pulley / idler set up , for lubrication free movement . just some things I have added , pete Share this post Link to post Share on other sites
