josephbruce11212@gmail.co 262 #1 Posted August 17, 2022 Does anyone have the valve stem size for 60's rims? Share this post Link to post Share on other sites
Handy Don 17,392 #2 Posted August 17, 2022 Sorry, I'm fully tubed! 1 Share this post Link to post Share on other sites
8ntruck 9,254 #3 Posted August 17, 2022 The one that fits? Having been an engineer in the automotive wheel industry for my 40 year carrier, I should know the size. But, I don't. It was always specified by the customer, and other than when moving from tubes to tubeless wheels while I was still in grade school, I don't remember any changes. The Tire and Rim Association is the keeper of standards to make sure tires, rims, tubes, valve stems, and wheel weights all work together regardless of who built the component. Try checking their web site? 1 Share this post Link to post Share on other sites
josephbruce11212@gmail.co 262 #4 Posted August 17, 2022 1 minute ago, 8ntruck said: The one that fits? Having been an engineer in the automotive wheel industry for my 40 year carrier, I should know the size. But, I don't. It was always specified by the customer, and other than when moving from tubes to tubeless wheels while I was still in grade school, I don't remember any changes. The Tire and Rim Association is the keeper of standards to make sure tires, rims, tubes, valve stems, and wheel weights all work together regardless of who built the component. Try checking their web site? Good to know, I will check the site. Share this post Link to post Share on other sites
Pullstart 71,175 #5 Posted August 17, 2022 Seems like .410 and .620 or something funky. Just less than 1/2” and just less than 5/8” 2 Share this post Link to post Share on other sites
squonk 48,010 #6 Posted August 17, 2022 .453" https://www.napaonline.com/en/search?text=90-413&referer=v2 3 Share this post Link to post Share on other sites
josephbruce11212@gmail.co 262 #7 Posted August 17, 2022 1 hour ago, Handy Don said: Sorry, I'm fully tubed! What size tube do you run? Share this post Link to post Share on other sites
rmaynard 17,557 #8 Posted August 17, 2022 (edited) I have adapters to make the .410 fit in the .625 holes. I can send you a couple, but..... I'm on vacation in Florida and won't be home until Friday. These allow the smaller stems on tubes to fit larger holes in rims. They are not for tubeless tires. Edited August 18, 2022 by rmaynard 3 Share this post Link to post Share on other sites
Snoopy11 5,731 #9 Posted August 17, 2022 2 hours ago, josephbruce11212@gmail.co said: Does anyone have the valve stem size for 60's rims? Here is what I use. Works AWESOME! https://www.amazon.com/VTR-TR-416-S-Outer-Mount-Metal/dp/B01BRVCQ7K/ref=sr_1_3?crid=2VX3FTBKS91DP&keywords=screw+in+valve+stem&qid=1660757527&sprefix=screw+in+valve+stem%2Caps%2C1349&sr=8-3 Don 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #10 Posted August 17, 2022 P.S. @josephbruce11212@gmail.co... those valve stems that I posted above fit .453" and .625" rim holes... AND... to top it off... they look KILLER!!! Don Share this post Link to post Share on other sites
Jeff-C175 7,211 #11 Posted August 17, 2022 (edited) 3 minutes ago, Snoopy11 said: what I use Would they work for both size holes Don? I bought a pair of rear wheels from Lincoln last year and one had the .453 and the other had the .625 sizes. Quote fit .453" and .625" rim holes... NEVER MIND! LOL! Edited August 17, 2022 by Jeff-C175 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #12 Posted August 17, 2022 Just now, Jeff-C175 said: Would they work for both size holes Don? Yes sir... they are listed to work for both size holes, and I can personally verify that they do work for both size holes. Don Share this post Link to post Share on other sites
Snoopy11 5,731 #13 Posted August 17, 2022 4 minutes ago, Jeff-C175 said: NEVER MIND! LOL! You'd be surprised how fast a grad student can type... Don 1 Share this post Link to post Share on other sites
Handy Don 17,392 #14 Posted August 17, 2022 1 hour ago, josephbruce11212@gmail.co said: What size tube do you run? Nothing fancy. 6x12 extra heavy duty in the rear (they were Silvertowns and in there when I got the tractor--I suspect original equipment); 4x8 heavy duty in the front (new and matches to tire sizes) For my use case (mowing ~¼ acre plus some towing and show touring), I'm expecting never to mess with those tires again as long as own this tractor. 1 Share this post Link to post Share on other sites
josephbruce11212@gmail.co 262 #15 Posted August 17, 2022 54 minutes ago, Snoopy11 said: P.S. @josephbruce11212@gmail.co... those valve stems that I posted above fit .453" and .625" rim holes... AND... to top it off... they look KILLER!!! Don Those are the ones I ordered....not holding air...hmmm Share this post Link to post Share on other sites
josephbruce11212@gmail.co 262 #16 Posted August 17, 2022 1 hour ago, rmaynard said: I have adapters to make the .410 fit in the .625 holes. I can send you a couple, but..... I'm on vacation in Florida and won't be home until Friday. That'd be cool! appreciate it! Share this post Link to post Share on other sites
Ed Kennell 47,156 #17 Posted August 17, 2022 1 hour ago, josephbruce11212@gmail.co said: Those are the ones I ordered....not holding air...hmmm Should the rubber washer be on the inside? 3 1 1 Share this post Link to post Share on other sites
josephbruce11212@gmail.co 262 #18 Posted August 17, 2022 37 minutes ago, Ed Kennell said: Should the rubber washer be on the inside? It came with 2 different rubber washer dependent on hole size. I installed with the first washer correctly. It leaked, so I was hoping if I added the other sized washer under the nut washer it would aid and seal.....it did not. 1 Share this post Link to post Share on other sites
josephbruce11212@gmail.co 262 #19 Posted August 17, 2022 I'm pretty sure its the bead leaking and not the valve stem.... 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #20 Posted August 17, 2022 40 minutes ago, josephbruce11212@gmail.co said: I'm pretty sure its the bead leaking and not the valve stem.... Yeah, I have used those things to death without issue... Don Share this post Link to post Share on other sites
Handy Don 17,392 #21 Posted August 17, 2022 (edited) 1 hour ago, Ed Kennell said: Should the rubber washer be on the inside? Should be steel and rubber washers on each side for that style, right? Spray some soapy water on the bead to see where it's coming out (or just throw the wheel and tire into the swimming pool). Edited August 17, 2022 by Handy Don 1 Share this post Link to post Share on other sites
Jeff-C175 7,211 #22 Posted August 17, 2022 1 hour ago, josephbruce11212@gmail.co said: I'm pretty sure its the bead leaking and not the valve stem.... You can always use soapy water to spot leaks! 3 Share this post Link to post Share on other sites
lynnmor 9,028 #23 Posted August 17, 2022 4 hours ago, josephbruce11212@gmail.co said: Those are the ones I ordered....not holding air...hmmm I use those on my travel trailer. They can easily be under or over tightened, it appears that you may have squashed the rubber too much. A bit of tire mounting lube on the rubbers allows them to better conform to the wheel. 1 Share this post Link to post Share on other sites
953 nut 68,913 #24 Posted August 17, 2022 2 hours ago, josephbruce11212@gmail.co said: I'm pretty sure its the bead leaking and not the valve stem.... 4 Share this post Link to post Share on other sites
josephbruce11212@gmail.co 262 #25 Posted August 17, 2022 4 minutes ago, 953 nut said: It should be possible to push the tires off the bead, clean with wire brush, bead sealer and fill, right? I'm not at all looking forward to having to remove the tires... if that is needed. Share this post Link to post Share on other sites
