ElevatorChris 0 #1 Posted August 15, 2022 Freshly rebuilt motor but try to figure out the wiring if anyone could help thanks Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,234 #2 Posted August 15, 2022 Welcome to Red Square Do you know the specification number of this engine? or what model of tractor it came from? 1 1 Share this post Link to post Share on other sites
squonk 46,561 #3 Posted August 15, 2022 The wire with the hook on the end and rubber grommet is supposed to go from the coil negative to the points. Why it's in the location it is is beyond me. 3 1 Share this post Link to post Share on other sites
SylvanLakeWH 31,390 #4 Posted August 15, 2022 Mods - this should be moved to electrical section for better exposure… this section is for battery powered tractors… 1 Share this post Link to post Share on other sites
953 nut 66,064 #5 Posted August 15, 2022 I see a coil wire with a spark tester apparently emerging from the engine flywheel cover which would indicate a Magneto Ignition system. I also see what appears to be the wire from a set of ignition points to a battery ignition coil. Got to know a bit more about this engine to give you the correct wiring. Please don't do anything involving putting power to the wires on this engine until we know the Spec number or the application it was installed on prior to being rebuilt. 2 Share this post Link to post Share on other sites
wallfish 19,986 #6 Posted August 16, 2022 (edited) Do you have a pic of the front? Edited August 16, 2022 by wallfish Share this post Link to post Share on other sites
The Freightliner Guy 1,363 #7 Posted August 16, 2022 Share this post Link to post Share on other sites
squonk 46,561 #8 Posted August 16, 2022 Now I'm thinking it's a magneto engine and that points wire is supposed to exit the shroud on the other side. 1 Share this post Link to post Share on other sites
953 nut 66,064 #9 Posted August 16, 2022 5 minutes ago, squonk said: Now I'm thinking it's a magneto engine and that points wire is supposed to exit the shroud on the other side. BINGO, that is why I didn't want any power applied to any wire until we know more about the engine. @ElevatorChris Share this post Link to post Share on other sites
