Bens vintage tractors 1,555 #1 Posted August 15, 2022 Found a pretty cool one today. Raider 12 with electric lift. Only bought it for the deck so if anyone is interested in the tractor let me know. 2 1 Share this post Link to post Share on other sites
Sparky-(Admin) 24,618 #2 Posted August 15, 2022 Interesting lift….not a factory setup (I don’t think it’s factory) Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,993 #3 Posted August 15, 2022 Share this post Link to post Share on other sites
Retired Wrencher 6,443 #4 Posted August 15, 2022 8 hours ago, gwest_ca said: Good post Garry. Now I have seen everything. 1 Share this post Link to post Share on other sites
Mike'sHorseBarn 3,417 #5 Posted August 15, 2022 That's cool and I've definitely never seen one before! Share this post Link to post Share on other sites
Thor27 848 #6 Posted August 15, 2022 Following along to see where this goes. Have same lift and a raider waiting its turn for some attention. 1 Share this post Link to post Share on other sites
Howie 900 #7 Posted August 16, 2022 Have one of those lifts on a tractor here also. I use the thing too. 1 Share this post Link to post Share on other sites
Sparky-(Admin) 24,618 #8 Posted August 16, 2022 On 8/14/2022 at 8:49 PM, Sparky said: Interesting lift….not a factory setup (I don’t think it’s factory) I stand corrected! I’ve never seen one like that before 1 Share this post Link to post Share on other sites
Hampton 95 #9 Posted August 16, 2022 Where do you attach something to lift? Share this post Link to post Share on other sites
Thor27 848 #10 Posted August 16, 2022 1 hour ago, Hampton said: Where do you attach something to lift? Under or with a cable out the rear same as any other wheel horse of that Era. The actuator just replaces the lift handle. Share this post Link to post Share on other sites
Hampton 95 #11 Posted August 16, 2022 11 minutes ago, Thor27 said: Under or with a cable out the rear same as any other wheel horse of that Era. The actuator just replaces the lift handle. I don't see a place to attach anything. No holes or what ever. Share this post Link to post Share on other sites
Thor27 848 #12 Posted August 16, 2022 (edited) Everything attatches exactly as it would to a similar horse without an electric lift. The actuator replaces the lift handle. the bell crank that normally operates off the lift handle is still there but attached to the front of that actuator. The rear of the actuator you see in the pictures is on a bracket that bolts to the rear axle and doesn't move. Edited August 16, 2022 by Thor27 Add pic. 2 Share this post Link to post Share on other sites
Hampton 95 #13 Posted August 16, 2022 2 hours ago, Thor27 said: Everything attatches exactly as it would to a similar horse without an electric lift. The actuator replaces the lift handle. the bell crank that normally operates off the lift handle is still there but attached to the front of that actuator. The rear of the actuator you see in the pictures is on a bracket that bolts to the rear axle and doesn't move. I mean I don't see anywhere to attach an implement. Share this post Link to post Share on other sites
ineedanother 1,853 #14 Posted August 16, 2022 15 minutes ago, Hampton said: I mean I don't see anywhere to attach an implement. Maybe this will help...the electric lift simply actuates the rocker to retract or extend the cable and (likely) chain to lift the attachment "rocking" behind the rear axle which can be accomplished a couple ways. I don't think I stated that clearly but I hope you can put the pieces together 1 Share this post Link to post Share on other sites
Hampton 95 #15 Posted August 17, 2022 (edited) I understand how the lift works. I mean this section I have circled. How do you attach something to it? Edited August 17, 2022 by Hampton Share this post Link to post Share on other sites
pfrederi 19,868 #16 Posted August 17, 2022 Looking at the manual you do not attach anything there. if you are using a slot or clevis hitch it is raised by the cable that goes through the tube up to the pivot arm under the hood stand. Same setup as if you were using a manual lift. Share this post Link to post Share on other sites
Thor27 848 #17 Posted August 17, 2022 4 hours ago, Hampton said: I understand how the lift works. I mean this section I have circled. How do you attach something to it? 19 hours ago, Thor27 said: The rear of the actuator you see in the pictures is on a bracket that bolts to the rear axle and doesn't move. Share this post Link to post Share on other sites
Hampton 95 #18 Posted August 17, 2022 So nothing on that end. Got now I think. duh lol Would like to see one in action. 1 Share this post Link to post Share on other sites
Bens vintage tractors 1,555 #19 Posted August 20, 2022 On 8/17/2022 at 1:00 PM, Hampton said: So nothing on that end. Got now I think. duh lol Would like to see one in action. IMG_5855.MOV IMG_5856.MOV Share this post Link to post Share on other sites
Hampton 95 #20 Posted August 21, 2022 Can you use it to raise and lower implements with a clevis hitch? Share this post Link to post Share on other sites
Thompson1276 257 #21 Posted August 22, 2022 Interesting that pretty cool bet that was useful in the yesteryears is that for the deck or rear attachments Share this post Link to post Share on other sites
Howie 900 #22 Posted August 23, 2022 It will lift whatever you put on the tractor just like the manual lift lever did. It basically just replaces the manual lift lever. Has its own specific rock shaft. Share this post Link to post Share on other sites
