Thompson1276 257 #1 Posted August 8, 2022 I had to replace the Ignition to my wheel horse a 3 point that’s hook up was B-S-I , my new ignition is I-S-B with ignition and battery swapped so I swapped the cable too , the battery had power , the solonoid has power I didn’t test the ignition I’m doing that tomorrow but I also took pics and have it hooked up the way it use to be so would there be a reason why this would happen I also hooked up a new light switch to the cig lighter and put on a Gen Warning light off a old Sears and put it on middle to S and the outside wire to I , and it didn’t even light up when I tried to start it and the rear light light switch light didn’t work. 1 Share this post Link to post Share on other sites
953 nut 69,558 #2 Posted August 8, 2022 This is how it was done from the factory. 41 minutes ago, Thompson1276 said: Gen Warning light off a old Sears and put it on middle to S and the outside wire to I , and it didn’t even light up Adding a solenoid would require some changes to make the generator light work. You can use the three prong switch and just run the "BAT" terminal of the regulator back to the battery. 1 Share this post Link to post Share on other sites
Thompson1276 257 #3 Posted August 8, 2022 2 hours ago, 953 nut said: This is how it was done from the factory. Adding a solenoid would require some changes to make the generator light work. You can use the three prong switch and just run the "BAT" terminal of the regulator back to the battery. It’s a 3 point system I have it the same as factory from my owners manual but nothing even a new ignition Share this post Link to post Share on other sites
Thompson1276 257 #4 Posted August 8, 2022 Just now, Thompson1276 said: It’s a 3 point system I have it the same as factory from my owners manual but nothing even a new ignition Has a solonoid already from factory running a 3 prong solonoid and the Battery Solonoid Ignition prong starter the lights go to the cig lighter switch that is from the second return on the Voltage reg 2 Share this post Link to post Share on other sites
953 nut 69,558 #5 Posted August 8, 2022 (edited) 8 hours ago, Thompson1276 said: Has a solonoid already from factory running a 3 prong solonoid and the Battery Solonoid Ignition prong starter the lights go to the cig lighter switch that is from the second return on the Voltage reg What model number ort year and HP are you working with here? I am unaware of any that came from the factory with a solenoid and a three pronged ignition switch. Did you buy this new from the factory with that switch and solenoid set-up? Edited August 8, 2022 by 953 nut 2 Share this post Link to post Share on other sites
rmaynard 17,589 #6 Posted August 8, 2022 If you user name is any indication of your model number (1276), here is the wiring diagram from the 1276 manual. Share this post Link to post Share on other sites
