ReelFaster 53 #1 Posted August 7, 2022 Any recommendations on deck blades for my 416-H rear discharge? I'd like to get mulching blades but can't seem to find them that easily. Thanks in advance! Share this post Link to post Share on other sites
8ntruck 7,833 #2 Posted August 7, 2022 I got a set for my 42" RD deck from my local Toro dealer last year. They are high lift blades, not mulching blades. The price was not too bad, either. 2 Share this post Link to post Share on other sites
ReelFaster 53 #3 Posted August 7, 2022 Does anyone know if side discharge and rear blades are the same and can be used? Thanks! Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,472 #4 Posted August 8, 2022 What is the model and serial number of the deck you have? When adding the blade part numbers to the illustrated parts list cover pages I recall two different blades changing to one but don't know where or when it happened. Click on the search box and then select Files from the drop down menu. Enter a blade part number and the search will find the mower decks that used that blade. Then search for the other part number. 1 Share this post Link to post Share on other sites
ReelFaster 53 #5 Posted August 8, 2022 7 minutes ago, gwest_ca said: What is the model and serial number of the deck you have? When adding the blade part numbers to the illustrated parts list cover pages I recall two different blades changing to one but don't know where or when it happened. Click on the search box and then select Files from the drop down menu. Enter a blade part number and the search will find the mower decks that used that blade. Then search for the other part number. That's a good question I need to pull the deck and get more information. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,472 #6 Posted August 8, 2022 Side discharge blades with 3/4" center hole 106636 set Rear discharge blades with 3/4" center hole 106635 set Recycler blades with 3/4" center hole 14-4879 set If you go to Oregon or Napa (Rotary) you may find two decks using the same blades. That may be where I saw it. 1 Share this post Link to post Share on other sites
