jameschap 7 #1 Posted August 4, 2022 my deck on my 416-8 is 3/4 inch higher on left side than right side and it scalps badly on right side..... i have checked all lift parts and readjusted all brackets and find no problem ....my question is could the deck be twisted from previous owner ??? Share this post Link to post Share on other sites
oliver2-44 11,098 #2 Posted August 4, 2022 Is it a 42” deck? They are not as solid as the 48” decks. Also have you checked the air in all your tires? A low tire can change the decks level. 1 Share this post Link to post Share on other sites
jameschap 7 #3 Posted August 4, 2022 yes its a 42 inch.... all 4 tires are new and just checked pressure..also put N.O.S. deck scalp wheels. also new blades and checked to make sure they were all same level.. Share this post Link to post Share on other sites
tunahead72 2,595 #4 Posted August 5, 2022 I don't know a lot about these, but the gage wheels on some of the 42" RD decks can be adjusted to level the mower from left to right. Do you have an owner's manual for your deck? Or do you know its model number? This may not be your mower, but check out Fig. 12 and the instructions above it in this manual to see if yours might look like that one: Mower Rotary 42in RD 1980-1983 05-42MR01 OM IPL SN.pdf - Mower decks & reel - RedSquare Wheel Horse Forum Share this post Link to post Share on other sites
Rick3478 445 #5 Posted August 5, 2022 Deck shells do sometimes get bent, especially from hitting tree roots. Also, the lift mechanism doesn't raise from the center, so if not adjusted right can hold one side up a bit. And it may sound stupid, but it's easy to put a blade on upside-down... 1 Share this post Link to post Share on other sites
8ntruck 8,397 #6 Posted August 5, 2022 The typical Wheel Horse deck rides on the gage wheels to control cutting height and levelness. The gage wheels are typically mounted on a rod that extends across the deck connecting the two gage wheels. If that rod gets twisted, it will probably put the deck out of level. Good luck. If you figure out what is wrong, let us know what you find. 1 Share this post Link to post Share on other sites
Handy Don 15,384 #7 Posted August 5, 2022 (edited) 16 hours ago, 8ntruck said: The typical Wheel Horse deck rides on the gage wheels to control cutting height and levelness. The gage wheels are typically mounted on a rod that extends across the deck connecting the two gage wheels. If that rod gets twisted, it will probably put the deck out of level. Good luck. If you figure out what is wrong, let us know what you find. Someone standing on the deck can cause that gage-wheel shaft to bend. Also, if it has been apart, make sure that the mounting clamps for that rod on both sides have the same spacers in them. May be a dumb thought, but are the two wheels the same diameter and with no play in the bushings? Edited August 5, 2022 by Handy Don 1 Share this post Link to post Share on other sites
