41chevy 74 #1 Posted August 3, 2022 Is it normal for the coil to get hot if the switch is left on? Share this post Link to post Share on other sites
squonk 45,534 #2 Posted August 3, 2022 Yes. The coil is only powered briefly per revolution. 2 Share this post Link to post Share on other sites
wallfish 19,322 #3 Posted August 3, 2022 And very hot too Share this post Link to post Share on other sites
Jeff-C175 7,207 #4 Posted August 3, 2022 30 minutes ago, 41chevy said: Is it normal for the coil to get hot if the switch is left on? And doing so is an easy way to destroy a coil ! You'll probably also kill your battery if left that way for a long period. They'll only get hot if the points are closed. If you're lucky enough to stop with them OPEN, the coil won't get hot since there's no current flowing through it. 1 Share this post Link to post Share on other sites
41chevy 74 #5 Posted August 3, 2022 Thank you, I’d just finish rewiring everything and accidentally forgot to turn the key. 2 Share this post Link to post Share on other sites
953 nut 64,127 #6 Posted August 3, 2022 You may want to give your ignition points the once over, they were not meant to have a steady flow for a long time. Share this post Link to post Share on other sites
