thomas koehler 6 #1 Posted July 30, 2022 I have a D-250 that I havew not had long. I was wondering if since it was built in the days of leaded gas if it would be beter for it if I used lead substitute mixed in the gas to prolong the motor. 2 Share this post Link to post Share on other sites
Sparky-(Admin) 26,322 #2 Posted July 30, 2022 Didn’t unleaded come out in like 1975? And your a few D-250 is newer than that. Share this post Link to post Share on other sites
ineedanother 2,864 #3 Posted July 30, 2022 Unnecessary. Just run 87 or 89 octane and limit the ethanol if you can. 2 Share this post Link to post Share on other sites
The Freightliner Guy 1,364 #4 Posted July 30, 2022 What about ethanol free like clear 88 at maverick 1 Share this post Link to post Share on other sites
peter lena 10,047 #5 Posted July 30, 2022 @thomas koehler been using ethanol gas for years , without issues , I do add STA BIL , to all my fuels , without any problems , you might also freshen up your fuel filter , filters . BTW looks like a perfect opportunity , to give that total unit a aerosol lubricant spray down , that starved paint would darken up and save patina , also shed water . give it a total spray down , let sit a day , rub down and do it again , its not hard to do , and would definitely freshen up appearance , and shed water like a good wax job,. do not use sand paper or scratch pads , only a clean cloth to wipe down that oiled finish , before and after pic , would be dramatically different , pete 1 Share this post Link to post Share on other sites
John2189 601 #6 Posted July 30, 2022 9 minutes ago, peter lena said: @thomas koehler been using ethanol gas for years , without issues , I do add STA BIL , to all my fuels , without any problems , you might also freshen up your fuel filter , filters . BTW looks like a perfect opportunity , to give that total unit a aerosol lubricant spray down , that starved paint would darken up and save patina , also shed water . give it a total spray down , let sit a day , rub down and do it again , its not hard to do , and would definitely freshen up appearance , and shed water like a good wax job,. do not use sand paper or scratch pads , only a clean cloth to wipe down that oiled finish , before and after pic , would be dramatically different , pete What spray lubricant do you use? Share this post Link to post Share on other sites
clueless 3,439 #7 Posted July 30, 2022 I assume they still sell leaded gas because every gas station, and convenient store I pass for the past 40 years advertises the unleaded price which would means there must be leaded someway. 3 Share this post Link to post Share on other sites
ineedanother 2,864 #8 Posted July 30, 2022 Banned with just a few exceptions about 25 years ago. Share this post Link to post Share on other sites
lynnmor 9,038 #9 Posted July 30, 2022 42 minutes ago, clueless said: I assume they still sell leaded gas because every gas station, and convenient store I pass for the past 40 years advertises the unleaded price which would means there must be leaded someway. All gasoline sold for use on the highway is unleaded. The unleaded signs at gas stations shows ignorance beyond comprehension. Share this post Link to post Share on other sites
peter lena 10,047 #10 Posted July 30, 2022 @John2189 you can use , marvel mystery oil , or wd40 , or similar penetrant , been using a regular paint feed on my horses for years , even on clean paint , it literally feeds the paint , pete Share this post Link to post Share on other sites
John2189 601 #11 Posted July 31, 2022 58 minutes ago, peter lena said: @John2189 you can use , marvel mystery oil , or wd40 , or similar penetrant , been using a regular paint feed on my horses for years , even on clean paint , it literally feeds the paint , pete Ok I have pblaster will that work? 1 Share this post Link to post Share on other sites
Wild Bill in VA 1,596 #12 Posted July 31, 2022 Unleaded gasoline came out in 1973 and was even called synthetic type gas by the media. Stelite valves and hardened valve seats is what it took to run the unleaded gas ..... dang I remember when Sunoco 260 came out of the pumps RED, now that was good leaded gas. Wild Bill in Richmond VA 3 Share this post Link to post Share on other sites
edgro 680 #13 Posted July 31, 2022 For a period of time you could get leaded (regular) and unleaded. Thats when they came out with the smaller nozzle tip so you could not put leaded gas into your unleaded car. Once the regular gas went away they never changed the name from unleaded. I have thought that too, why call it unleaded, it's all unleaded, they should be calling it regular Share this post Link to post Share on other sites
killroy 36 #14 Posted July 31, 2022 Just like no smoking signs on airplanes. Haven't been able to smoke on a plane in a long time but they still have the no smoking 🚭 signs Share this post Link to post Share on other sites
thomas koehler 6 #15 Posted August 1, 2022 (edited) Lots of good advice. Thank you all. Edited August 1, 2022 by thomas koehler Share this post Link to post Share on other sites
peter lena 10,047 #16 Posted August 1, 2022 @killroy almost funny now my last smoking flying experience was many years' ago , coming back from florida , smokers in the back , of course smoke fumes were everywhere , the good old days , pete 1 Share this post Link to post Share on other sites
Beap52 2,476 #17 Posted August 2, 2022 If I remember, when it first was offered for sale, unleaded gas was more expensive than regular or ethyl gas. At the time I used only ethyl gas in my motorcycles and the fellow I worked with only burned ethyl gas in his 1971 Ford pickup. He believed that the additional cost for ethyl over regular leaded gas paid for itself through better fuel economy. Back then, the gas station attendant would come out, pump your gas and while doing so wash the windshield. Then if you has an account there, your would sign a ticket while sitting in your car and come in once a month to pay your bill. It also seemed that when using leaded gas one thing I looked for was a light gray or whitish deposit inside the tailpipe. That supposedly showed an engine that was tuned-up correctly and not an oil burner. Then came unleaded gas and tailpipes didn't have this whitish deposits. Now, the tailpipes are on clean running engines don't have any deposits. We also enjoyed "gas wars". I have bought gas for as little as 19 cents per gallon. Of course I was paid two dollars per hour. Back then even a penny or two per gallon was a significant savings. We lived in a small town. The gas stations closed early and if my motorcycle needed fuel "after hours" I drained the gas in the gas pump lines to get me home. The hoses were much longer back then. 1 Share this post Link to post Share on other sites
953 nut 69,162 #18 Posted August 3, 2022 On 7/30/2022 at 3:40 PM, clueless said: I assume they still sell leaded gas because every gas station, and convenient store I pass for the past 40 years advertises the unleaded price which would means there must be leaded someway. Kind of like a speakeasy during prohibition, you need to pull around to the back of the gas station and ask for Joe. On 7/30/2022 at 8:58 PM, Wild Bill in VA said: dang I remember when Sunoco 260 came out of the pumps RED, now that was good leaded gas Most of us who used 260 didn't have a high compression engine that benefited from the higher octane, but it made us feel like we had a rocket ship. Share this post Link to post Share on other sites
