Cee245 846 #1 Posted July 27, 2022 Does anyone have a source for a OEM rebuild kit for a Nikki 6100 146-0478? I've tried the bay and jungle site with no luck. This is what I believe to be for an older P series Onan twin. I think it does NOT have the emissions stuff on it, but I'm not sure of the difference between this one and the one from my 97 416. I have seen lots of what seem to be cheaply made kits(15-25) and whole carbs for less than 50. I want to stick to actual oem stuff if I can. TIA Share this post Link to post Share on other sites
lynnmor 8,254 #2 Posted July 27, 2022 This is probably the one you want. Often those carburetors can be carefully disassembled, cleaned and reassembled without any new parts. You can buy just the gaskets if the float and needle are OK. If you have the late model carburetor with an accelerator pump, that is available on the same site. 1 Share this post Link to post Share on other sites
