RED-Z06 2,681 #1 Posted July 23, 2022 On my C161 that the previous owner put a Tec OH160 on, I've gotten the wiring mostly sorted except charging. The engine has wires off the stator, they go into the engine mounted regulator and exit a single wire into the factory harness which feeds the ammeter then the ammeter heads up to what would be the acc spade on an ignition switch Here's my issue...while running it shows 0vdc at that wire but had about 48vac, id assumed that the tecumseh regulator also rectified it to dc but maybe not? What am i missing here 1 Share this post Link to post Share on other sites
peter lena 9,457 #2 Posted July 23, 2022 @RED-Z06 how are your ground related points ? don,t count on existing related areas , unless refreshed , take out bolts , sand down area , dielectric oil / grease , serrated washers to bite into metal , just an idea , pete 1 Share this post Link to post Share on other sites
RED-Z06 2,681 #3 Posted July 23, 2022 I hooked it up to the switch...figured whats the worst that could happen. 13.7idle 14.8 wot...i guess it needs 12v backfed to it to work... 2 1 Share this post Link to post Share on other sites
ebinmaine 74,575 #4 Posted July 23, 2022 56 minutes ago, RED-Z06 said: I hooked it up to the switch...figured whats the worst that could happen. 13.7idle 14.8 wot...i guess it needs 12v backfed to it to work... Interesting info there. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,744 #5 Posted July 23, 2022 The regulators must see battery voltage to turn them on so to speak before they can regulate the charge current. A good test is to turn the key to the RUN position without the motor running and check regulator DC+ voltage at the regulator for battery voltage. This covers all models as some are wired directly to the battery somewhere and others are switched at the ignition switch. At the end of the day with battery voltage you know the charge current has a way to get to the battery and that is all that matters. There is a service bulletin that states the regulator must see at least 4 volts but best to stick with the battery voltage. There could be 8 volts lost to poor connections and that is a problem. 3 Share this post Link to post Share on other sites
RED-Z06 2,681 #6 Posted July 23, 2022 Its charging great, really surprised to be honest. 2 2 Share this post Link to post Share on other sites
ebinmaine 74,575 #7 Posted July 24, 2022 14 hours ago, RED-Z06 said: Its charging great, really surprised to be honest. I'm not the least bit surprised. These old engines and tractors are built quite heavy from the start. That engine you have is VERY interesting to see and I'm happy it's on a Wheelhorse. If you lived closer I'd be lookin' to own it. 🤠 1 Share this post Link to post Share on other sites
RED-Z06 2,681 #8 Posted July 24, 2022 2 hours ago, ebinmaine said: I'm not the least bit surprised. These old engines and tractors are built quite heavy from the start. That engine you have is VERY interesting to see and I'm happy it's on a Wheelhorse. If you lived closer I'd be lookin' to own it. 🤠 I guess its just that over 20 some odd years of working on small engines, tecumsehs have nearly consistently proven to be the worst, of all the engines ive had personally and then many thousands ive worked on..only 2 have failed catastrophically, both tecumsehs. I almost passed on the free tractor when he mentioned it had a tecumseh 😂. I do have a few tecs though, H50s, H60s, HH60s, a couple HM100s. 1 Share this post Link to post Share on other sites
