Bradshawn 49 #1 Posted July 20, 2022 Good evening I’m in the process of tearing down a c-81 have some broken wires in the fuse block. I’m trying to source a replacement with no such luck. Is Another configuration possible? As far as twinning wires together and using inline fuses? I’m not too familiar with electrical work. I’m a dumb welder 😂 Share this post Link to post Share on other sites
Achto 30,040 #2 Posted July 20, 2022 Here is one option for you. https://www.ebay.com/itm/224443123860?chn=ps&_trkparms=ispr%3D1&amdata=enc%3A1DG1yrb3HT76R36niXWmG5A47&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=224443123860&targetid=&device=c&mktype=pla&googleloc=9019452&poi=&campaignid=17597089569&mkgroupid=&rlsatarget=&abcId=9300988&merchantid=101681445&gclid=CjwKCAjwrNmWBhA4EiwAHbjEQHDdeqWEVfTny7sbnNCwt1a583cHny-6_rJG-gEo6y5C4SNYY7MOnhoCf2AQAvD_BwE 4 Share this post Link to post Share on other sites
Bradshawn 49 #3 Posted July 20, 2022 5 minutes ago, Achto said: Here is one option for you. https://www.ebay.com/itm/224443123860?chn=ps&_trkparms=ispr%3D1&amdata=enc%3A1DG1yrb3HT76R36niXWmG5A47&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=224443123860&targetid=&device=c&mktype=pla&googleloc=9019452&poi=&campaignid=17597089569&mkgroupid=&rlsatarget=&abcId=9300988&merchantid=101681445&gclid=CjwKCAjwrNmWBhA4EiwAHbjEQHDdeqWEVfTny7sbnNCwt1a583cHny-6_rJG-gEo6y5C4SNYY7MOnhoCf2AQAvD_BwE Great! I wasn’t aware I could use a automotive fuse block. Thank you very mich 2 1 Share this post Link to post Share on other sites
Achto 30,040 #4 Posted July 20, 2022 The more water proof the better. 1 1 Share this post Link to post Share on other sites
Jeff-C175 7,207 #5 Posted July 20, 2022 1 minute ago, Bradshawn said: Great! I wasn’t aware I could use a automotive fuse block. Thank you very mich If you wanna stay original, check with Lincoln at AZ tractor (see vendor forum here for contact info) 2 Share this post Link to post Share on other sites
Bradshawn 49 #6 Posted July 20, 2022 21 minutes ago, Jeff-C175 said: If you wanna stay original, check with Lincoln at AZ tractor (see vendor forum here for contact info) I don’t mind not staying original on this but I’ll check them out thanks 2 Share this post Link to post Share on other sites
Jayzauto 89 #7 Posted July 20, 2022 GEvening Bradshawn, https://wheelhorsepartsandmore.com/product/fuse-block-replacement-67-7160/ Here is the fuse box I used on several of my tractors. It's OEM style, Very Simple to install, has everything you need, worx great and available from a vendor that advertises here.. Great people to deal with GLuck, Jay 1 1 Share this post Link to post Share on other sites
Bradshawn 49 #8 Posted July 20, 2022 18 minutes ago, Jayzauto said: GEvening Bradshawn, https://wheelhorsepartsandmore.com/product/fuse-block-replacement-67-7160/ Here is the fuse box I used on several of my tractors. It's OEM style, Very Simple to install, has everything you need, worx great and available from a vendor that advertises here.. Great people to deal with GLuck, Jay Oh and it has the ends too that’s sweet and 2 extra slots I can add lights ?! 2 Share this post Link to post Share on other sites
lynnmor 8,146 #9 Posted July 20, 2022 (edited) Just Google Dorman 85668 and buy according to price or convenience. This cap is expensive, but it will protect the fuse block. Edited July 20, 2022 by lynnmor 1 Share this post Link to post Share on other sites
peter lena 9,517 #10 Posted July 20, 2022 @Achto @Bradshawn agree with you on the automotive fuse block set up , why not install something better ? wiring and faulty connections are a major area of disfunction , , would also add a wiring reroute , and wiring cable wrap , to eliminate chafing / shorting connection areas . while you are doing that , insure / verify a ground connection cable from battery cable ground bolt down point , don't think its grounded , add a wire to the area . use an alligator test clip wire to insure ground function , then hard wire it . only a suggestion . stay grounded , pete 2 1 Share this post Link to post Share on other sites
